LED's in port? - Car Audio Classifieds!
Old 03-09-2013, 02:57 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default LED's in port?
bought some strip led's for the port in my box and trying to figure out the best way to run them... I cant run them off the power and ground for my amps or else they will always be on, so what will be the best way to power them, a relay?
Old 03-09-2013, 03:00 PM
hotzie's Avatar
changin the game up
0/11 ssssss793
d do the relay thing , do you have a relay for your amps ? if so thats where id tap in to , if not id get a relay and do it that way especially for multiple amps
Old 03-09-2013, 03:02 PM
Ryan1126's Avatar
0/11 sssss9178
only one amp. wiring up a relay is a lot of work for some lights, its in my girlfriends car, and there isnt any distros, so i would have to come all the way from the battery. could i possibly splice off of the remote, will that provide enough power to run the leds?
Old 03-09-2013, 03:05 PM
badmofo529's Avatar
0/11 sssss3329
Wire the relay to the amp terminals then
Sent from my Inspire 4G using Tapatalk 2
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
hotzie's Avatar
changin the game up
0/11 ssssss793
thats what i was thinkin , whats the power requirments on the leds?
Old 03-09-2013, 03:07 PM
Ryan1126's Avatar
0/11 sssss9178
Electrical Specs:
Input Voltage: 12VDC
Power Consumption: 24W (about 2 amps) per 16.4 foot roll
its only a 6" strip
DLP customs
Guest
0/0 sssssssss
When i did mine a few years back i ran them to my switching 12v on my deck wires and ran it to a switch so i could manually shut them on and off. I only had 4-5 leds tho not a whole strip.
Matt3824's Avatar
0/11 sssss3754
Just take the time to wire in a relay. It's worth it, all you'll need it in the future anyway.
Old 03-09-2013, 03:09 PM
Ryan1126's Avatar
0/11 sssss9178
what relay would you recommend? 4 pin?
Old 03-09-2013, 03:53 PM
0/11 ssssss759
you could just run it to a toggle switch no replay needed ... or use ur remote from the amp as power and ground it then the lights will only come on wen the amp does .. if u want to contol the lights being on / off thow a toggle switch in there and ur set...
Powering LED's and fans and more LowLyfe General Car Audio Discussion & Questions 10 09-01-2011 12:15 AM
VLEDS led's gbo559 Off Topic Chat 31 08-26-2011 03:42 PM
Replacing lights with LED's 92K1500 General Automotive Chat 8 06-08-2011 06:06 AM
Oznium LED's Ryan1126 Off Topic Chat 10 01-20-2010 12:31 AM
Oznium LED's gbo559 Off Topic Chat 42 11-24-2009 11:30 PM
