15" Zv3 on Aq2200, need opinions! - Car Audio Classifieds!
Old 03-11-2013, 12:53 AM
0/11 ssssss398
Default 15" Zv3 on Aq2200, need opinions!
Okay so I purchased a 15" Sundown Zv3 and im going to be running it off of my Aq2200, I listen to mostly decaf music, 25hz and up, so the question is, what tuning should I shoot for, and should I go with recommended specs (3cubes) or should I go smaller/larger. The sub is going in a Scion Tc and im wanting to do sub up port up, so that it loads off the slanted glass, because if I load off the back hatch, it chokes the sub out due to the box and slant of the hatch. IDEAS PLEASE! Ive got roughly 38W, 10-15H, 15-20D (H/D depends on the other, because the taller the shorter, or shorter the longer due to hatch slant)
Old 03-11-2013, 03:26 PM
0/11 ssssss398
Bump.
Old 03-11-2013, 10:46 PM
0/11 ssssss398
Bump!
Old 03-12-2013, 12:06 AM
witherman's Avatar
Will work for subs
0/11 sssss2280
3.0-3.5 and shoot for 32-34hz, should be doable with your dimensions and dig down pretty well. Don't clip it with that amp :-)
Old 03-12-2013, 12:10 AM
0/11 ssssss398
3.25 @ 32hz was recommended to me, Ill try that
Old 03-12-2013, 12:12 AM
witherman's Avatar
Will work for subs
0/11 sssss2280
Good deal
Old 03-12-2013, 12:29 AM
0/11 ssssss398
Im having issues making it work in torres though, im looking at sub up port up, 3.25cf, 32hz, with 50-60sqft of port, ive got like 38W 18D 16H to work with looking to move decent amount of air so I like alot of port
FS: 2 ZV3 Motors and one ZV3 12" Basket Winter_C Broken & Non-working equipment 17 02-18-2013 04:58 PM
zv3 opinions ToNasty (Sundown Audio) 0 02-09-2013 11:34 PM
box opinions for 2-Zv3 15 on a saz3.5k in trunk crazybones2084 (Sundown Audio) 21 09-04-2012 09:17 PM
Four zv3 15"s vs two zv3 18"s on the same power. Mnorwood01 (Sundown Audio) 11 08-04-2012 05:41 PM
Should I sell my two zv3 18"s and get four zv3 12s to get louder. Mnorwood01 (Sundown Audio) 25 06-18-2012 04:13 PM
