Aeroport Advice Needed - Car Audio Classifieds!
Old 08-01-2009, 02:15 PM
strpperpolef150's Avatar
Ladies love my pole
0/11 sssss3814
Default Aeroport Advice Needed
For my next build I plan to use a single 6" aero. This will be the first time I've messed with aero's and would like some opinions on purchasing the needed materials.
The length with dual flared ends is 30"
My question to you is what is the best way to go about getting this length:
Buy a 17" aero kit and an extra tube then cut it to length
or
Buy the flared ends and purchase pvc to cut to length
If you have other options please post them. Thanks for looking
-Single cab F150-
HU: Kenwood KDC-X993
Processing: Clarion EQS746
Front stage: (2x) Shok CB 6.5
Comp amp: Crescendo 1000C4
Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
sub amp: (2) SAZ-2500s strapped @ 1
Electrical: Mike Singer 250a alt, D3100, (2) NSB90, 70+ft of shok
New numbers coming soon.....
I buy shifted motors
- Team PSI - Team Shok -
Louisiana/Mississippi Crescendo Rep
Old 08-01-2009, 02:23 PM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
The less joints you have the better, just for simplicity's sake. PVC is also cheaper from my experience.
Old 08-01-2009, 02:25 PM
Ladies love my pole
0/11 sssss3814
Yea I'm leaning towards the cheaper side since it is $52 for the first option and a lot cheaper for the second.
Now say I go the pvc route. Is there a certain thickness I need for the pvc? Will the flares fit correctly?
-Single cab F150-
Old 08-01-2009, 02:28 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Buy the flares and take them with you and figure out how to make it work.
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
Old 08-01-2009, 02:29 PM
Ladies love my pole
0/11 sssss3814
This is what I have thought about doing, just want to see if there are any pro's and con's to doing so.
-Single cab F150-
Old 08-03-2009, 12:36 PM
Ladies love my pole
0/11 sssss3814
up for more opinions
-Single cab F150-
Old 08-03-2009, 12:50 PM
Veteran Member
0/11 sssss4401
There shouldnt be any cons.
It would be the safest thing to do so you dont have to waste money.
Sub: ---
Speaks: ---
Headunit: ---
Old 08-03-2009, 12:56 PM
0/11 sssss6101
the only two cons of using PVC vs pre-made aero are the following:
you'll have to paint the PVC, which may or may not be a b*tch depending on your ability with a rattle can
also, from my knowledge, PVC can be a huge P.I.T.A to cut when it's that large. Something smaller, I'd say use a hacksaw, but 6" is pretty big.
Old 08-03-2009, 12:59 PM
0/11 sssss7816
Sawzall ftw.
Atomic Loudspeakers
Audiotechnix
Old 08-03-2009, 01:00 PM
Veteran Member
0/11 sssss4401
You can use a table saw or circular or just a sawzall.
Sub: ---
Speaks: ---
Headunit: ---
Need a bit of advice madmat Off Topic Chat 17 02-01-2010 11:23 PM
Guitar Advice needed mytyeerinpie Off Topic Chat 21 05-18-2009 09:27 AM
where is that cheap aeroport website ? upzaw2000 General Car Audio Discussion & Questions 2 05-09-2009 11:40 PM
aeroport question RidnClean General Car Audio Discussion & Questions 9 04-17-2009 09:16 PM
need advice please Snwbrdr1 General Car Audio Discussion & Questions 34 03-06-2009 12:09 AM
