reuse enclosure? - Car Audio Classifieds!
Old 03-11-2013, 05:02 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Default reuse enclosure?
i currently have 2 12" Zv3 in a birch enclosure that is 40"Wx25.5"Lx16.25H and the port is 6"Wx32.5"Lx14.75"H . 7.89 gross/ 5.65 net/ 88.5" port/ 15.66 per
do you think if i remove the top and put a new layer i can use the same enclosure for 2 dc level4 15 m1 subs? i know dc recommends 3.25 cubes per sub and i have less than that.
this is in my '03 santa fe and i would have them wired to 2 ohms on my xta-5000d
here are pics of it as it is.i removed the .75" from the dimensions i posted because the top is double.
My game is legit,
Old 03-11-2013, 09:19 PM
jt_buck's Avatar
don't shoot
0/11 sssss4425
Meh, build a new box.
Old 03-11-2013, 09:26 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
i have 0 funds. my disability was terminated and i am still in the process of getting social security. that is why i was wondering if it would work. if it will i'll do it and maybe sell the Zv3 subs. if not i'll just sell the level 4 subs.
My game is legit,
Old 03-11-2013, 09:34 PM
jt_buck's Avatar
don't shoot
0/11 sssss4425
I just don't think it'll be worth it.
Old 03-11-2013, 09:38 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
damn. i can do small hairtricks with the 2 12"s but i wanna do bigger and the more cone area would definately help. i don't chase numbers anymore. i just wanna pound. thanks for your input.
My game is legit,
Old 03-11-2013, 09:41 PM
newarkbeast973's Avatar
0/11 sssss7810
if you're just making the baffle then why not just try it out. If it doesn't work then just put old baffle back on and sell the 4's
New build coming soon!!
Old 03-11-2013, 09:49 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
because the old baffle will be no good anymore. i'd be cutting it off with a circular saw.
My game is legit,
Old 03-11-2013, 09:51 PM
0/11 sssss7810
I see. didn't think of that.
Old 03-11-2013, 10:16 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
It can be done. I've cut enclosures in 1/2 before to utilize one sub....then used the scrap wood to fill in areas needed and bondo where beeded. I got pics to prove this. But, can weaken the wood overtime, because of so many screwed holes/nails. But if wood glue is used, I'd say you might be good.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 03-11-2013, 10:19 PM
you might get away with it because it's a common chamber, it will play peaky more then likely though.
edit: it's actually pretty close to what a generic design for 2 subs that do well at 3.25ft each would like in a common chamber design.
Enclosure Build: 10" IAD Reign Demo Enclosure ;) Pioneer~Saturn Build Logs 57 11-18-2012 03:58 PM
Reuse deadener KNOTDUDE General Car Audio Discussion & Questions 7 05-03-2012 04:11 PM
Enclosure Build: maintrain's home enclosure Pioneer~Saturn Build Logs 80 01-19-2010 05:32 PM
reuse my box? Bushj311 General Car Audio Discussion & Questions 14 12-11-2009 07:31 PM
Enclosure Scapelli21 Wanting to Buy (WTB) 0 11-13-2009 03:13 PM
