box help for tahoe wall - Car Audio Classifieds!
Old 03-16-2013, 01:39 AM
916slapin's Avatar
0/11 ssssss825
Default box help for tahoe wall
I want to do alot of 10s in my tahoe in a c pillar wall. My dimensions are 48 wide 36 deep 38 high I was thinking of 24 10s. Is this possible? It is 30 cubes if I do 2 layers of wood on each side.
Old 03-16-2013, 01:42 AM
Tiller's Avatar
0/11 sssss1427
All you can do is sealed... Can't port it with that much space....
If your going to wall it why not just go to the b pillar? You'd be half way there?
"I'm not addicted I'm committed"
Old 03-16-2013, 01:46 AM
916slapin's Avatar
0/11 ssssss825
I wanna keep back seats I saw a suburban with a cpillar wall and he did 12 15s I thought I could do 24 10s lol
Old 03-16-2013, 01:55 AM
916slapin's Avatar
0/11 ssssss825
What about a low ratio 4th order 10 cubes sealed 20 ported
Old 03-16-2013, 02:20 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I don't see how that's going to work. If the 10's want 1 cube a piece, that leaves you with only 6 cubes for port and bracing. How are you going to fit all those subs on one face? Say, for example, a 10" sub takes up a 10 by 10 square inch space on the face of the box roughly. So 10 x 10 = 100 square inches of space taken up. 24 subs = 24 x 100 = 2400 square inches of sub space needed. 38h x 48w = 1824 square inches. You have to fit what will work on the face unless you want a clam-shell or bandpass but get ready for severe reductions in airspace.
Old 03-16-2013, 02:24 AM
916slapin's Avatar
0/11 ssssss825
What do you guys recommend how many 10s
Old 03-19-2013, 10:28 PM
916slapin's Avatar
0/11 ssssss825
Anyone else have an idea on what else I can fit on here how many 10s
Old 03-19-2013, 11:09 PM
ridintwo6s's Avatar
0/11 sssss1791
A suburban is 2 feet longer then your Tahoe
Not to mention one of the most talented enclosure builders in the game built it
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 03-19-2013, 11:23 PM
916slapin's Avatar
0/11 ssssss825
Didn't know one of the most talented built it, it looks like a sick build any opinions on what I could do
Old 03-19-2013, 11:24 PM
jheist1991's Avatar
0/11 sssss1070
Unless I'm not understanding how a wall works, at least a plain old flat wall, the measurements you gave limit you to 3 10 inch subs tall and 4 wide. Depth not as important if you're trying to get them all on the same plane for a wall, as it just helps provide the airspace.
So if you can go 3 subs tall and 4 wide, that gives us 3 rows of 4 subs, for a total of 12 tens. so a giantly oversized flat wall, or a 4th order with 12 sealed, and 18 ported. Small ratio 1:1.5.
Edit: on that note, 12 tens is still pretty damn impressive and should get down just fine with good power. My vote goes to the 4th. Should be nasty loud and still musical. And you still get the wow effect of 12 tens.
Phoenix gold Tahoe c pillar wall stylez12321 General Car Audio Discussion & Questions 9 02-05-2013 06:01 PM
luck with a 2nd row tahoe wall? AlanHall General Car Audio Discussion & Questions 4 01-30-2013 12:38 PM
01 Tahoe C-pillar wall. 03tbls Build Logs 51 11-28-2012 10:29 AM
02 Tahoe Box agp1976 Enclosure Discussion & Design Construction Help 2 07-19-2011 08:23 PM
Ideas for box for '03 Tahoe FAUEE Enclosure Discussion & Design Construction Help 0 07-19-2010 01:28 AM
