Box Help for HDC3 15 - Car Audio Classifieds!
Old 03-16-2013, 03:30 PM
0/11 sssssss20
Default Box Help for HDC3 15
Just got my hdc3 in the other day and could use some opinions. The current box is a little under 4 cubes at 30 with not nearly enough port area. I have heard these subs like bigger boxes with lots of port area. You guys think 4.5 cubes at 32 would be good for this sub? Might do a 6 or 8 inch sonotube port, if not just a normal slot port. Im going to try sub up on the drivers side with the port side firing to the passenger side. Any help or suggestions would be appreciated.
Old 03-16-2013, 03:40 PM
0/11 ssssss220
From what I've read (Soundqubed's website) they like higher tuning also. Like 38hz or so.
Old 03-24-2013, 11:30 AM
duff_thrust's Avatar
0/11 ssssss629
They do like a bit higher tuning. I had 2 tuned to 35 hertz and it sounded awesome without sacrificing any lows. Look more towards about 4.5 cubes with around 17 square inches of port per cube and that's after all displacement. And bracing is a must. I guess it really depends on how much power you're giving it. On a slot port go with roughly 1:5- 1:6 port height to width ratio.
12 hdc3 box ? burd337 General Car Audio Discussion & Questions 13 11-13-2011 01:37 PM
Need Help Please!!! HDC3 18 box 423bass Enclosure Discussion & Design Construction Help 3 08-02-2011 09:18 PM
box for 2 18 hdc3 423bass Enclosure Discussion & Design Construction Help 6 07-04-2011 12:28 PM
need help with new box for AQ hdc3 18 extremechevyman67 Enclosure Discussion & Design Construction Help 10 10-19-2010 12:20 PM
box sizes for HDC3-HDC3-A Fosgate1 General Car Audio Discussion & Questions 1 10-01-2009 10:26 AM
