Is this too rediculous? 15-12's in a truck bed - Car Audio Classifieds!
Old 03-17-2013, 08:20 PM
0/11 ssssss463
Default Is this too rediculous? 15-12's in a truck bed
It takes up my entire bed within the wheel wells (batteries on the sides). Ratios look OK. Port is maxxed out (can't cut anymore). Anybody seen one similar to this and how did it sound?
Any comments are appreciated.
BTW I built this one and it sounds awesome!
Old 03-17-2013, 08:28 PM
Micksh's Avatar
0/11 sssss2596
I think you would be better served going less subs and a larger ratio. The gain in efficiency would offset the loss in cone area and your port would be closer to what you need sq in wise.
My Youtube page
Astro build log link
Old 03-17-2013, 09:27 PM
0/11 ssssss463
How about this. Ratios are almost perfect 2:1. 45%port/cone area.
Old 03-17-2013, 10:28 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
That looks a lot better for sure
2000 2dr Blazer
Old 03-17-2013, 10:54 PM
mega fatty
0/11 sssss6008
I've been told the long low 4ths don't load properly and the rear drivers may unload prematurely.
Could you fit 8 with a V?
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-17-2013, 11:19 PM
0/11 sssss1417
you could time align if you have enough amps and do it in rows. keep the phase closest to the port at 0. then the next row up the phase, then the next a little more etc.
Old 03-17-2013, 11:43 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Not uncommon at all. I got a AS&S mag an old issue that has 8 pyle pro subs in a bandpass type enclosure utilizing the bed of his truck with a thick piece of lexan covering the top.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
truck bed battery box help AQ28576 General Car Audio Discussion & Questions 2 03-10-2013 03:33 AM
.rediculous deal my_stealth21 eBay 18 10-04-2011 02:50 PM
looks like im going to miss a few shows since my alternator poop the bed in the truck loudmofo Off Topic Chat 11 07-13-2011 12:49 AM
Rediculous! D'90's General Car Audio Discussion & Questions 16 11-27-2010 02:59 AM
