4th order design for 2 rival 15s, check my work? - Car Audio Classifieds!
Old 03-20-2013, 01:44 PM
0/11 sssssss27
Default 4th order design for 2 rival 15s, check my work?
So I have spent some time fooling with winisd and torres and have come up with 2 4th order designs that will fit in my space(03 subaru outback)
I have read in a couple places that box 1 has some issue with the port being aligned with the sealed chambers, and that the best design is to have the subs in separate sealed chambers in the back of the enclosure, much like box 2. Anyone care to confirm or deny this? I would prefer to use the 1st design just because it will tend to be louder ported back rather than to the side like box 2 does.
This is also my first 4th order build so if I am making any mistakes feel free to jump in a point them out. Box is for 2 rival 15", (similar to dc level 3s) on an alpine mrp2k
Old 03-20-2013, 03:47 PM
jt_buck's Avatar
don't shoot
0/11 sssss4425
Sealed portion seems small.
Old 03-20-2013, 04:21 PM
0/11 sssssss27
Old 03-20-2013, 04:22 PM
0/11 sssssss27
It's obviously not to proportion in the drawing, but are you saying I need more than 3.4 cubes sealed for the both of them?
Check my 4th order specs? nicyousuckk Enclosure Discussion & Design Construction Help 18 12-10-2012 10:32 AM
Check my 4th order figures. nicyousuckk Enclosure Discussion & Design Construction Help 0 12-08-2012 12:03 AM
will this work for a 4th order Ringspun09 Enclosure Discussion & Design Construction Help 2 12-07-2011 11:40 PM
one last check on 4th order tymoto21 Enclosure Discussion & Design Construction Help 29 07-10-2011 08:55 PM
double check my 4th order? twisted Enclosure Discussion & Design Construction Help 22 01-22-2010 06:40 PM
