what would you do wall vs 4th - Car Audio Classifieds!
Old 03-25-2013, 05:42 PM
0/11 sssssss76
Default what would you do wall vs 4th
I have enough room for a ported wall with 6 18" or I can do a 2:1 4th order with 6 15".
what would you do and why??
I can't make up my mind.
I'll be running only 8kw.
thanks
Old 03-25-2013, 06:35 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
How many cubes do you have?
2000 2dr Blazer
Old 03-25-2013, 06:39 PM
0/11 sssssss76
around 42
Old 03-25-2013, 06:48 PM
ridintwo6s's Avatar
0/11 sssss1791
should be able to get a larger ratio 4th then that.
what subs?
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 03-25-2013, 07:30 PM
0/11 sssssss76
what subs?
for the 4th, probably lvl3's or SA15's
for the wall lvl3 or 4's
Old 03-25-2013, 08:51 PM
0/11 sssss5201
42 cubes
1.66 cubes per sealed(add poly fill) -10cubes
5.33 cubes per ported- 32 cubes
42 cubes puts ya at a 1:3 ratio
2000 2dr Blazer
Old 03-25-2013, 09:23 PM
0/11 sssssss76
would it be better than a ported wall with more cone area?? I've never heard a 4th order so I'm undecided.
Old 03-25-2013, 09:26 PM
0/11 sssss5201
A correctly tuned 4th is great. Numbers and lows all in one box I would do a 4th, but I'm biased
2000 2dr Blazer
4th order wall or flat wall Dirtbikerrob Enclosure Discussion & Design Construction Help 9 03-05-2013 09:25 PM
4 OA 18s. Wall or 4th? btsteinb Enclosure Discussion & Design Construction Help 36 08-21-2012 02:35 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 08:37 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 03:01 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 06:50 PM
