4th order for 2 OA 18's - Car Audio Classifieds!
Old 03-26-2013, 06:24 PM
0/11 sssssss60
Default 4th order for 2 OA 18's
Im looking to wall off the back of my car and put a 4th order with 2 Obsidian Audio 18's. I am planning on doing 9 cubic feet sealed and around 22.5 cubic feet ported. this will give me a 2.5:1 ratio. << is that good?
I have been looking around at some 4th order programs and im just not sure what to believe. I know that I need to find the resonant frequency of the sealed part and tune the port to that frequency but im not exactly sure how to find that.
If anyone can help or chime in it would be greatly appreciated. Thanks
Old 03-26-2013, 06:27 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
2.5 each sealed i beleieve. 9 is wayy too much msg hackmunch about 4th for oa's
Old 03-26-2013, 06:29 PM
0/11 sssssss60
ya but on their website it recommends 3.5-5 for a sealed? or is it completely different for 4th order? sorry this will be my first 4th order
Old 03-26-2013, 06:33 PM
0/11 sssssss60
And I believe I sent him a message the other day and haven't heard back
Old 03-26-2013, 06:40 PM
djscrubb's Avatar
0/11 sssss2332
or read the 4th order thread fully i do beleive i asked about the oa 18's as i used to have a couple
Old 03-26-2013, 06:43 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
You can get away with less sealed volume on the sealed half of a 4th order than you can in just a standard sealed box. Also adding polyfill in the sealed chamber will help save space by making the sealed side seem/act larger.
You will be able to get 3:1 or higher ratio easy if you have 30+ cubes to work with. 9 cubes sealed is way too big IMO.
6 psi 18's in a 4th order wall tommytee Build Logs 28 02-27-2013 03:29 PM
FI BL 18's 4th order wall? 98Expo Enclosure Discussion & Design Construction Help 4 01-24-2013 07:14 PM
need a box design. 4th order 2 18's loudcivic Enclosure Discussion & Design Construction Help 0 04-16-2012 08:06 PM
need help/advice od a 4th or 6th order for 2 18's tahoefixssd Enclosure Discussion & Design Construction Help 1 09-13-2011 12:19 AM
4th order design 2 18's jdmferio13 Enclosure Discussion & Design Construction Help 1 10-21-2010 09:09 PM
