How's this for 2 sa8 v1.5s - Car Audio Classifieds!
Old 03-27-2013, 09:26 PM
fivedollapizza's Avatar
0/11 ssssss314
Default How's this for 2 sa8 v1.5s
3/4 mdf
Box outside dimensions:14h*25w*13.5d
Port dimentions: 2.25w*12.5h
Sub chamber: 14h*21.25w*7d
Starting from the port exit, it goes down the left side, then the back wall, flips a 180 and runs back, ending 2.25" from the inside of the first port wall, if that makes sense. Its ~54" of length. This seems crazy long to get a 34hz tuning, which is what Torres says it is.
I already built it and it plays LOW. Like "Rack City" shakes the hell out of dash and steering wheel while damn near floating my sunroof low. Can also do the same with a 19hz test tone.
Are my calculations off or have 8" subs just come this far?
Asking here because I've been talking to another guy with 2 sa8 v2s on similar power (1100–1200 rms) and he says his don't do this.
His box is 1.5cu/ft chamber with 30" of port which his designer said would be 35hz.
Thanks for the help guys. This is my first box and I'm very impressed with the output of it just wondering why then huge difference between mine and his.
Attached a pic to show how the port runs.
sent from my gs3
Old 03-27-2013, 09:38 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
i got 1 cube net with a 36hz tuning, 54" long
thats without double checking like i usually do
Old 03-27-2013, 09:41 PM
0/11 sssss1417
thats alot of screws.
Old 03-27-2013, 09:44 PM
0/11 ssssss314
So mine seems right then? It just plays a lot farther past the 34-36 thats its tuned to. First box and learning as i go so not sure hoe this all works.
sent from my gs3
Old 03-27-2013, 09:48 PM
0/11 ssssss314
It leaked on the outside. And was pretty sure it was leaking internally as well. Found a box of 2" drywall screws on a shelf at work, bought a 6 pack and made DAMN SURE it doesn't leak lol
sent from my gs3
Old 03-27-2013, 09:59 PM
sthrnbumpn's Avatar
0/11 sssss2961
just becareful not to create more leaks,
when ever i put together a box.... i use way more glue than screws,
it takes me a few days to reglue all the seams afterwards
Old 03-27-2013, 10:07 PM
0/11 ssssss314
^^^^ noted. Going to rebuild cause I'm not very pleased with how panels line up and such.
Why can I still get that much air movement in the low 20s/high teens with a box tuned at 36? Is that how it always is?
sent from my gs3
Old 03-28-2013, 06:09 AM
sthrnbumpn's Avatar
0/11 sssss2961
sounds like a good ratio of volume and port, you got it right on this one
Old 03-28-2013, 06:27 AM
0/11 ssssss228
just because the box is tuned to a certain freq doesnt mean it wont play anything lower than that freq
Old 03-28-2013, 08:49 AM
0/11 ssssss314
Yeah I just didn't know how far below tuning they would go. Going to tune a bit lower next time. Want more output on songs like Machine Gun Kelly's "Hold On"
sent from my gs3
How's this look? all4spl Enclosure Discussion & Design Construction Help 16 11-23-2012 09:19 PM
How's it going sosoleful New Member Orientation 5 08-10-2011 02:01 AM
How's it going? Big Nick New Member Orientation 6 11-17-2010 11:42 PM
How's this look? Dunbar91 General Car Audio Discussion & Questions 3 08-30-2010 09:08 PM
How's it hangin? New here... Bob'O New Member Orientation 16 04-20-2009 05:50 AM
