Enough port area? - Car Audio Classifieds!
Old 03-28-2013, 07:59 AM
turkishvalo's Avatar
0/11 sssss1418
Default Enough port area?
Ok so this box will be 4.2 cubes tuned to 31hz. Im not familiar with aeros. I want to use one 6inch. Is 6.71 per enough? 28.26 cubic in?
HU-Pioneer DEH-7200HD
Front Stage-CDT EU6s Alpine SPR-10TW tweeters,
Front amp-PPI 900.4
Sub stage-2 Fi btl 12s
Sub amp- 2 Crescendo BC2Ks Strapped at 2
Mechman 240. Team gg.
Old 03-28-2013, 08:19 AM
vince79vette's Avatar
0/11 sssss2011
I would go with a single 8in port. The 6in wont be enough.
Sent from Chuck Norris foot
Old 03-28-2013, 08:28 AM
0/11 sssss1418
I dont think an 8 will work. I would have to be retarded long to get the tuning I want. But anyway its already been confirmed that it will be fine. Thanks. I guess the rule of thumb on aeros is 6 to 9 per
Front amp-PPI 900.4
Old 03-28-2013, 08:47 AM
skinnyg's Avatar
0/11 ssssss828
that rule of thumb is also bullshit
Old 03-28-2013, 08:50 AM
0/11 sssss8594
Feedback Score: 55 reviews
i think the 6" will be fine but a 8" will give u better spl with those tantrics...but to answer your question, yes it will work...how deep of a box are u making?
Enclosures
0/11 sssss1418
Elaborate? This is what I got from 99Bonney on here.
Front amp-PPI 900.4
Old 03-28-2013, 08:51 AM
0/11 sssss1418
21 inches. I can go as big as 24d, 15 h and 35w
Front amp-PPI 900.4
Old 03-28-2013, 08:55 AM
0/11 sssss8594
easily done...your prbably gonna want to go shorter on your width tho...u can keep the port inside the box...you only need 13" of port to tune down to 32hz...so figure 13" plus 3-6" away from back wall plus your mdf...plenty of space
Enclosures
Old 03-28-2013, 09:00 AM
99Bonney's Avatar
0/11 sssss6246
Trust me, that rule of thumb is not BS. Every box I've built with 6-9" per cube has worked well and was very musical. Obviously for Spl purposes I would choose an 8" aero. But that's not his only intention with this setup.
The Following User Says Thank You to 99Bonney For This Useful Post:
fyerbyrd22 (03-28-2013)
Old 03-28-2013, 09:02 AM
skinnyg's Avatar
0/11 ssssss828
Originally Posted by turkishvalo View Post
Elaborate? This is what I got from 98Bonney on here.
that "rule of thumb" works, but is usually overkill, motor strength, input power, and xmax are a better determining factor. With that rule you cant go wrong usually.
I just hate to see where some poor guy has like 500w on a couple 12s with 7mm xmax and a 4 cube box and people are telling him he has to shove a 8" port into it lol, when a couple 3s would probably be ok
experience also comes into play really, you will just be like yea that looks good, but too much never hurts
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 10:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 10:52 PM
port area for 1 sa 12?? thekernal123 (Sundown Audio) 7 05-25-2011 10:14 PM
port area lantz Enclosure Discussion & Design Construction Help 10 12-27-2009 03:03 AM
