My 6th order design - Car Audio Classifieds!
Old 03-28-2013, 01:32 PM
0/11 sssssss29
Default My 6th order design
So, I am mostly a lurker and have been reading up on 6ths for a while and think I actually might have a design that'll work. The thread that was really helpful was one over on caco (idk if I'm allowed to post the link here. I will if I'm allowed) but here's a summary of what I've learned:
Inner box- generally to ported specs (volume), ~3-5sq in port per foot, tuned low (aeros work well to keep port noise down)
Outer - volume depends on ratio wanted - 1:1 fairly flat between tuning points, 1:2(inneruter) peak near higher tuning point, 2:1 peak near low tuning point. Port - 35-50sq in port per foot, tuned one octave higher than inner box (one octave higher is double the one below it - ex: 60 is one octave above 30hz)
general rule of thumb: don't have ports firing into each other. inner ports need to be able to load off a wall
If there's anything I missed, please correct me
My design:
Inner-
Outer-
Cutaway -
Finished box -
Sorry for bad sketch ups, I'm still new to it
Old 03-28-2013, 01:44 PM
209native's Avatar
0/11 sssss1975
your on caco
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 03-28-2013, 01:49 PM
0/11 sssssss29
Originally Posted by 209native View Post
your on caco
Am I in the wrong area? I posted in enclosure design
Old 03-28-2013, 01:54 PM
209native's Avatar
0/11 sssss1975
My design:
Inner-
Outer-
Cutaway -
Finished box -
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
6th order design help darkkon Enclosure Discussion & Design Construction Help 2 08-23-2011 06:37 PM
6th order design Vasilios Enclosure Discussion & Design Construction Help 7 06-04-2011 03:42 AM
My 6th Order design Mazdasadc Enclosure Discussion & Design Construction Help 24 04-12-2011 03:06 PM
6th order design need help maybe jmitch Enclosure Discussion & Design Construction Help 0 10-03-2010 07:40 PM
6th order design J&T DESIGNS Build Logs 34 07-15-2010 07:59 PM
