Box Advice - Car Audio Classifieds!
Old 03-28-2013, 01:06 PM
tntahoe's Avatar
0/11 sssss1196
Default Box Advice
Ok first off I already have a box built and installed in my Charger and here is a video of it: current box
The box is 31.5"w x 14.25"h x 22"d, 4 cubes after displacements, 6" aero thru rear deck tuned 32-33Hz. Now I'm thinking about building another box with a slot or square port down the center on the same plane as the 12s firing into the cabin. The 12s are Obsidian Audio and running them off a Crescendo 3kwp. I would like to get the most out of this setup, but Im not chasing numbers. I just want a loud to the ear daily setup. The setup I currently have sounds good but I think I could get more out of it. Im restricted on the height and width of the box but I have a few more inches in depth that I could use. So should I go with more or less box volume? I know subs can handle more power in smaller boxes so what do you all think I should do?
Old 03-28-2013, 01:44 PM
0/11 sssss1898
Have you tried a subs forward port side desgn yet
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 03-28-2013, 01:48 PM
tntahoe's Avatar
0/11 sssss1196
No I was actually planning on sealing it off from the trunk area to minimize some of the rattles and by firing the port to the side I couldnt seal it off. Also forgot to mention that I dont normally ride around with my rear seats folded down.
Old 03-28-2013, 05:21 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Subs forward port forward. sealed off from the trunk. The 32 width you have to work with should be fine to get both subs and port on same plane. Talk to JT Buck. He does really good designs and is based out of the Nashville area I believe.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 03-29-2013, 08:32 PM
tntahoe's Avatar
0/11 sssss1196
Anyone else?
Sent from my HTC One X using Tapatalk 2
Box advice! CEGrizzly General Car Audio Discussion & Questions 13 11-13-2012 02:07 PM
box for sa12? need advice please akrja_07 Enclosure Discussion & Design Construction Help 14 10-27-2012 07:36 PM
Advice on box design HazeGrey75 (DC) 2 02-26-2012 11:23 PM
Need box design/advice/BOTH EclipseChris Enclosure Discussion & Design Construction Help 1 02-03-2011 08:36 PM
Need box advice please! 4 10s F-150 t1990le Enclosure Discussion & Design Construction Help 11 12-11-2010 03:15 PM
