Sa 10 box volume q's - Car Audio Classifieds!
Old 03-29-2013, 08:04 PM
Twitney181's Avatar
0/11 ssssss591
Default Sa 10 box volume q's
Is 6 cubes to much space for 4 sa 10's? 1.5 per sub? They will be running off 2 tx1.2000 soundstream amps, (so maye 3k all together) it will be ported to 30hz. I've bought all my wood for it and am ready to go.hopefuly will be starting it on Monday so I'd love all your opinions. Here's the design
Old 03-29-2013, 08:32 PM
Twitney181's Avatar
0/11 ssssss591
Anyone
Old 03-29-2013, 08:34 PM
0/11 ssssss518
You should be fine, 6 cubes should let those subs get down!!!!
Just out of curiosity how much port are you using
Old 03-29-2013, 08:36 PM
Twitney181's Avatar
0/11 ssssss591
Good! And whatever 9" wide, 6" tall and 20" long is haha
Old 03-29-2013, 08:42 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
9 x 6 = 54 sq in of port,
54/6 = 9" per cube
that seems kinda small for 4 10's
Old 03-29-2013, 08:48 PM
Twitney181's Avatar
0/11 ssssss591
54/6 = 9" per cube
That just what I can fit without bending the port, think I should lengthen it? Or make it wider? I really wanted to avoid making it bend, it's about 6 cubes, I need to figure out the volume that the triangular prism takes out out of te space, anyone care to figure out and do the math?
Old 03-29-2013, 08:50 PM
Twitney181's Avatar
0/11 ssssss591
54/6 = 9" per cube
I don't exactly get the whole ratio thing. Ad how do you get that from 9 x 6? How does that take into account for thelength
Old 03-29-2013, 09:05 PM
sthrnbumpn's Avatar
0/11 sssss2961
port area is l x w
port area usually tells people how the sub/box volume will balance out
all port volume is used for is to figure your net box volume (subtract it from gross)
Old 03-29-2013, 09:07 PM
Twitney181's Avatar
0/11 ssssss591
port area is l x w
Makes sense now ha what would you recommend per cube?
Old 03-29-2013, 09:08 PM
sthrnbumpn's Avatar
0/11 sssss2961
usually the more power you have..... the more area you need to move air for all the extra excursion an such
Box for AfroBass 2 18" FI Q's GetLikeMe Build Logs 16 11-07-2010 12:18 PM
Box volume testing shizzzon (DC) 16 06-29-2010 10:10 PM
Noob Box Q's... mattinthebox Enclosure Discussion & Design Construction Help 7 07-25-2009 10:07 AM
Box volume gbo559 General Car Audio Discussion & Questions 3 07-15-2009 04:51 PM
Box build for 2 12" Fi Q's SPY Off Topic Chat 14 04-16-2009 03:12 PM
