Physical port vs port length? - Car Audio Classifieds!
Old 03-29-2013, 11:08 PM
Twitney181's Avatar
0/11 ssssss591
Default Physical port vs port length?
What's the difference between the two? What is the physical port length and what is regular port length?
On my box I designed my port length is 27 inches and my physical port length is 20.5 inches.
Old 03-29-2013, 11:11 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Is it a slot? Maybe it's panel length vs. effective port length? Or is it an end correction thing?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 03-29-2013, 11:14 PM
Twitney181's Avatar
0/11 ssssss591
It's a 9" x 6" slot port that DOES have an bend in it
Old 03-29-2013, 11:20 PM
Twitney181's Avatar
0/11 ssssss591
From what I read, I build it to the physical port length? I think. To account for the 90 degree bend in the port?
Old 03-29-2013, 11:28 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Panel length is the length of the pieces of wood you use to make the port. The effective port length is measured down the centerline of the port. The two will be different for sure.
4x world champ
- Floyd E. Toole
Old 03-29-2013, 11:30 PM
Twitney181's Avatar
0/11 ssssss591
So the pieces of wood I cut will be the shorter number right? The 20.5 inches?? I DON'T make the pieces of wood I cut 27" right?
Old 03-29-2013, 11:36 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Correct.
Say you have your port that's 6" wide. When it makes the turn, it doesn't turn with the panel. It goes down the centerline. So, the effective port will go 3" past the corner of the panels. The other 3-4" is probably an end correction because when using a common wall with the box, the effective port length extends one half of the width of the port past the panel end.
I guess it's kinda hard to explain. Lol.
4x world champ
- Floyd E. Toole
Old 03-29-2013, 11:38 PM
Twitney181's Avatar
0/11 ssssss591
Correct.
Thank you!! Makes sense now
help with physical port length MERQUE Enclosure Discussion & Design Construction Help 6 02-14-2012 06:43 PM
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 03:01 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
Port Length realrich159 General Car Audio Discussion & Questions 0 05-19-2011 03:55 PM
