Lexan/polycarbonate glass for sub box? - Car Audio Classifieds!
Old 03-31-2013, 02:26 PM
Twitney181's Avatar
0/11 ssssss591
Default Lexan/polycarbonate glass for sub box?
So I'm looking to do a window on my box for my 4 sa 10's, the window will be approximately 8" by 15". But I'm wondering if 1/2 inch will be thick enough or if I need to go thicker?
Old 03-31-2013, 02:49 PM
0/11 sssss6075
I'd go 3/4" for a window that big
Old 03-31-2013, 02:52 PM
the window needs to be as thick or thicker then the wood it replaces.
Old 03-31-2013, 03:28 PM
Matt3824's Avatar
0/11 sssss3754
Lexan is stronger than plexi, so saying that it needs to be equal thickness( be it 3/4 or 1/2 or whatever) is not a fair comparison. If you need 3/4 in plexi, you might only need 1/2 in Lexan. I'm going to use 1/2" Lexan on a
Box I'm currently building.
Old 03-31-2013, 03:39 PM
Twitney181's Avatar
0/11 ssssss591
That's what I'd read is that lexan is much stronger. Maybe ill just go 3/4 inch then.
Subs box and console all glass and amp jonatan Car Audio Packages 3 11-27-2011 05:43 PM
strong box 4 10s screws or staples glass or not scfaust Enclosure Discussion & Design Construction Help 15 03-27-2011 10:00 AM
[SOLD] Audiovox "Glass Guard" Glass Breakage Sensor toolguy420 Wiring, Electrical & Other Installation Equipment 15 09-14-2010 11:49 PM
wwt fiber glass box and subs ed 13s and amp bretv9669 Car Audio Trader (WTT) 0 06-12-2010 07:45 PM
acrylic and lexan (polycarbonate) Nudels Tutorials & Quick References 0 08-15-2009 04:25 PM
