Box for PSI 10" - Car Audio Classifieds!
Old 03-31-2013, 05:44 PM
Brand New Members
0/11 ssssssss4
Default Box for PSI 10"
I just purchased a PSI Platform 2 10" woofer. Only thing i know for sure is that my target box volume is 1.35. My question is what should i tune my box to and how much port area does this sub like?
My goal is overall output and Id like it to hit nice lows. I listen to mostly hiphop and frequently listen to Decaf.
I will be putting 1200 RMS to it.
If you guys could point my in the right direction, I would appreciate it.
My max dimensions are 24"W 13"H 13"D
Old 03-31-2013, 06:28 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
I can get back to you with a design tonight If you'd like
Louder. Lower.
Team Tupperware
Old 03-31-2013, 06:40 PM
Brand New Members
0/11 ssssssss4
that would be greatly appreciated
Old 03-31-2013, 08:33 PM
0/11 sssss8346
Laying it out here and before port(s) displacement is factored in youre starting at 1.3797 cubic feet :/ (I have a double layered baffle layed out on it) so I'm not sure how optimal we can make things. There's no way to go larger? And what vehicle/where in the vehicle will this be?
Louder. Lower.
Team Tupperware
Old 03-31-2013, 08:44 PM
Brand New Members
0/11 ssssssss4
Maybe we can compromise on the size of the box. Literally can't go any bigger. This is going in a miata lol! Or maybe utilizing areo ports
Old 03-31-2013, 08:51 PM
0/11 sssss8346
Yea, aeros will be a must...just a warning that your airspace goal and, most likely, fairly low tuning will be a bit of a stretch.
Louder. Lower.
Team Tupperware
Old 03-31-2013, 09:23 PM
0/11 sssss8346
Well, man...with it being so small, I'm having a hard time fitting an aero/aeros with any real length to them...if theyre in there the woofers dont have room to be mounted (And im just guessing that you dont have the room to invert them). So I went with a small slot port and about the best that I can get is 1.13 cubic feet net @ 36hz...not overly optimal in my mind but could 'work'. For this kind of space I would, personally, run a single 10" in an optimal enclosure.
Louder. Lower.
Team Tupperware
Old 03-31-2013, 10:47 PM
Brand New Members
0/11 ssssssss4
I think you might have misunderstood me. I have a SINGLE platform 2. 10" subwoofer.
I was playing around with the re box calculator and came up with this.
W 24"
H 12"
D 13"
Square Port Width 1.5"
Square Port Length 10"
I got 1.34 cubes and 34.1 Hz?
Old 04-01-2013, 04:10 PM
0/11 sssss8346
W 24"
H 12"
D 13"
Wooooooow...bahaha. My bad, I mustve not been able to read last night... well then, I think things will workout just fine. I'll get back with you tonight.
And yea, with that extra woofer's displacement out of the way that'll be good space for a proper enclosure
Louder. Lower.
Team Tupperware
PSI Platform 2 12" New Box Build Thread Eth anol Build Logs 5 09-29-2012 10:07 AM
Box/Aero port advice on PSI Plat 2 12" Eth anol Enclosure Discussion & Design Construction Help 6 09-26-2012 08:37 AM
AQ/PSI 18" Box Design Question zone6teddy Enclosure Discussion & Design Construction Help 12 03-13-2011 12:25 AM
PSI 15" sub in 30hz box! mischief05 15" Subwoofers 43 12-09-2010 11:42 AM
box for ported 12" PSI P1 Mac2118 Enclosure Discussion & Design Construction Help 2 04-16-2010 08:28 PM
