Port question - Car Audio Classifieds!
Old 03-31-2013, 10:59 PM
Twitney181's Avatar
0/11 ssssss591
Default Port question
I'm wondering if I can get away with configuring my port this way, so it's a 9" x 6" slot port, and gives me 11.89 sq inches of port area per cube. But anyways, my port needs to be 20" long, my box depth is 23" deep, and I'm wondering if I can just do a straight port (no bends) and have a 3" space between the rear of my box and the port, or do I need to make the port bend, so that it would be 18" deep, and have a 2" bend downwards.
I thought I read that I need as much space between my port and a wall of the box Atleast the width of the port, or is that only for aeros?
Old 03-31-2013, 11:48 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
You should probably make it 17" long to keep it a port's width away from the back wall. With the end correction, it should be pretty close to your tune anyway.
If I have to make a 2-3" bend like that... I don't even bother.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 04-01-2013, 08:50 AM
Twitney181's Avatar
0/11 ssssss591
So you say just go 17" long and leave it at that, or go 17 and make the 3" bend??
(Meant 17" before ha not 18")
Old 04-01-2013, 08:54 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
17 inches deep to leave distance from the back wall, you can do an L port and add get your 23 inches... i dont quite remember the rule for that though, but i dont think its straight forward where your L would just be 6 inches.
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 04-01-2013, 08:56 AM
0/11 sssss4519
I wouldn't bother with the bend when it's less than half of the width. ie off my port is 10 wide I won't make the bend unless it's 5" our more in additional length..
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 04-01-2013, 09:02 AM
Twitney181's Avatar
0/11 ssssss591
How much do you thnk that'll raise my tuning by? 20.5" long tunes me and 29.71hz, but with the bend I was gonna put a kerfed piece of MDF on the back 90 degree angle of the bend to help air flow. But 17" would be about like 33-32hz(ish)??
Old 04-01-2013, 09:09 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Use the same calculator you did, but also take into account, by shortening the port you also gain box volume.
TEAM DURTY POWA!!!
Old 04-01-2013, 09:31 AM
Twitney181's Avatar
0/11 ssssss591
Alright, we'll if it can keep it under 32hz ill just leave it as so, if not ill throw a little bend in there
Old 04-01-2013, 09:39 AM
newarkbeast973's Avatar
1/11 sssss7810
Off topic. You need to remove your damn sig!!! I can't stop looking or move to different threads until I force myself to!
New build coming soon!!
Old 04-01-2013, 05:39 PM
0/11 sssss4519
My wife catches me staring at it and usually slaps me lol
resolve Vas/28.32 =
result of that +1
question about L port and center firing port fyerbyrd22 Enclosure Discussion & Design Construction Help 10 10-10-2012 04:51 PM
Question about port up vs port back 916slapin Enclosure Discussion & Design Construction Help 8 03-14-2012 08:14 AM
port question for OA 15 arntsmag General Car Audio Discussion & Questions 26 11-21-2010 06:46 PM
L port question dylan9999 General Car Audio Discussion & Questions 41 08-22-2010 12:01 AM
port question fiBl18 General Car Audio Discussion & Questions 6 06-18-2010 03:37 PM
