Do you subwoofer mounting screws come loose? - Car Audio Classifieds!
Old 04-01-2013, 07:18 PM
fivedollapizza's Avatar
0/11 ssssss314
Default Do you subwoofer mounting screws come loose?
Two times now since I put my subs in my car I hear a horrible noise, quickly turn it down thinking "shit I blew my new subs," pull over, and one is leaking air around the gasket somewhere. They've been in for less than a month.
I've never had this problem before and want it to stop! What's the deal?
sent from my gs3
Old 04-01-2013, 07:24 PM
younggunzbass01's Avatar
0/11 sssss1653
what type of wood is your baffle made of and what type of screws are you using?
Ginger Filternator Impala Wagon pt. 2
12 12's
10k
Build log here
Old 04-01-2013, 07:27 PM
badmofo529's Avatar
0/11 sssss3329
You're probably over tightening them
Sent from my Inspire 4G using Tapatalk 2
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 04-01-2013, 07:30 PM
0/11 ssssss314
3/4 mdf (single layer), 1" drywall screws. Not the self tapper kind for metal studs.
When I first did the holes, I went about 3/4 of the way in with a drill on each, then hand tightened after that. I guess they could be overtightened, not exactly sure how to know for sure.
sent from my gs3
Old 04-01-2013, 07:44 PM
0/11 sssss1380
dont predrill the holes and use a #10 screw no issues
drywall screws suck and if you reuse them then they will probly snap
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
Old 04-01-2013, 07:46 PM
0/11 sssss1653
sent from my gs3
plywood and thicker screws. I use sheetmetal hex head 8mm screws. Get so tight into double baffled birch that my corded drill wont go any tighter with zero stripping.
12 12's
10k
Build log here
Old 04-01-2013, 07:51 PM
0/11 ssssss314
Hmm hadn't thought of just using a thicker screw lol. Have to take em out the weekend, rotate a bit, and replace with thicker screws. Thanks guys. Will report back if they do it again.
Edit: what's the plywood suggestion about?
sent from my gs3
Old 04-01-2013, 07:58 PM
0/11 sssss1653
sent from my gs3
plywood has actual sheets of wood anchored together so your screwing into solid wood. Whereas MDF your basically screwing into glued together wood pulp. Make sense?
12 12's
10k
Build log here
Old 04-01-2013, 08:01 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
take the screws out, shove a couple toothpicks in there and put the screw back in.
Old 04-01-2013, 08:02 PM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
true story. I broke three on one sub before.
Team XS Power
Team Heavy Hertz
Build-
youtube-
PDX amp parts; stacking screws, machine screws, rca plugs, cover screws nismos14 Wiring, Electrical & Other Installation Equipment 1 10-26-2012 07:12 AM
Subwoofer mounting question. k3n12ock General Car Audio Discussion & Questions 23 10-18-2012 03:18 PM
Subwoofer mounting issues :( regizzle Enclosure Discussion & Design Construction Help 7 01-31-2012 02:12 PM
Found out why sub screws keep coming loose....member here built the box AR-15 General Car Audio Discussion & Questions 105 08-10-2011 12:21 AM
Screws holding sub keep coming loose.... AR-15 General Car Audio Discussion & Questions 31 06-16-2011 07:48 PM
