What should I do? - Car Audio Classifieds!
Old 04-03-2013, 04:47 AM
jheist1991's Avatar
0/11 sssss1070
Default What should I do?
So today I got bored and traded my 15 inch AB HD sub for a couple new ones to play with. I ended up getting 2 Pioneer TS-w5000spl subs, one of them needs the tinsel lead soldered back together.
Since I probably won't have 5k worth of power to use both any time soon, I figured I'd build a good box and go with one for now. For power I'll have a Planet Audio BB2400 and with a single sub, the lowest I can wire is 2 ohms
The only enclosure info I can find for these is at this link, which only says 1.5 cubes.
Pioneer TS-W5000SPL Competition SPL Component Subwoofer User Manual
Does anyone else have any experience with this sub and have any ideas of what I should do box wise for it? Keep in mind that this thing is ~ 75lbs and like 9-11 inches tall. It's a beast.
Old 04-03-2013, 04:58 AM
ridintwo6s's Avatar
0/11 sssss1791
so yours is dual 4?
what does it being 75 pounds have to do with it only needing 1.5 cubes?
with your power id aim for around 3 cubes after displacements.
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 04-03-2013, 05:05 AM
jheist1991's Avatar
0/11 sssss1070
Originally Posted by ridintwo6s View Post
so yours is dual 4?
I'm just not used to seeing subs this size and weight need such little airspace
I know that everyone says these suck for daily listening and that their for SPL only, but I figured I'd try and get one to sound somewhat loud and decent.
So you'd recommend 3 cubes or so, after displacement for everything? I was thinking of tuning lower to like 30-33 or so.
Old 04-03-2013, 05:21 AM
ridintwo6s's Avatar
0/11 sssss1791
Quite a few bit of big 12s use 1.5 - 2 cubes per.
with you only have ~1000 watts or less, youll want the efficiency of a larger enclosure which is why i recommended 3 cubes.
Team HateD
Team Sundown
Old 04-03-2013, 05:58 AM
jheist1991's Avatar
0/11 sssss1070
Ok Cool I mocked up an enclosure I've used in the past with good results in sketchup but altered it to fit the ~3 cubes you suggested, tuning should come out to around 32 or so with this. Feel free to look over this design and make any suggestions.
