Which is a better sealant/adhesive for metal and wood? - Car Audio Classifieds!
Old 04-04-2013, 04:44 AM
0/11 ssssss253
Default Which is a better sealant/adhesive for metal and wood?
I'm sealing up my holes and openings for all 4 of my door panels to seal them off for better mid bass response, better mid bass reproduction and better mid bass kick/thump for my Forcal Utopia 6.5" Components and my Focal K2p 6.5" Components.
What is a better sealant and adhesive to bond the metal door panel to my wood?
General Electric Silicone 1 100% Rubber Sealant Wood & Door that says it bonds to wood. Has a score of 0-7. Wood has a score of 7 and Metal scores a 5
or
Heavy Duty Liquid Nails Adhesive that says it bonds to wood and Metal without a score.
What do you guys think?
I attached pictures of my first door.
File Type: jpg CameraZOOM-20130331194727128-1398314733.jpg (103.3 KB, 9 views)
File Type: jpg CameraZOOM-201304012458000152134999359.jpg (100.8 KB, 9 views)
2008 GMC Sierra SLE2 Z60 Crew Cab Texas Edition
JVC KW-NT800HDT, 2 Audiopipe 18001D's, Audiopipe AQX360.4, Phoenix Gold Tantrum 500.2, Focal Utopia's, Focal PS165 Comps in Q-Logic Kick Panels, Focal K2P comps w/ DD T1 Tweeter, 4 Sundown SA-8 V.2 Stock SPL's, 3 cuft box tuned to 31hz firing forward, Mechman 270a alternator, XS D3400
Old 04-04-2013, 04:56 AM
0/11 ssss31258
I would choose the silicone because it is easier to work with and can be easily cut to remove the panels if you need to.
if it's 'permanent' then liquid nails would work.
either way, make sure not to breath the fumes.
Construction Adhesive or Wood Glue?? Winter_C Enclosure Discussion & Design Construction Help 13 07-30-2012 09:41 PM
Adhesive Advice only126db (Fix My Speaker) 0 05-01-2012 08:24 AM
Sticking metal to metal jt_buck Sound Deadening & Fabrication 31 10-22-2011 02:07 PM
what enclosure glue/adhesive? loud-n-low Enclosure Discussion & Design Construction Help 20 06-27-2011 12:02 AM
what type adhesive More spl General Car Audio Discussion & Questions 18 02-13-2011 07:07 PM
