4-15s Wall Build - Car Audio Classifieds!
Old 04-05-2013, 06:55 PM
0/11 sssssss21
Smile 4-15s Wall Build
Okay guys so I am going to build me a wall in my Extended Cab F150. I am going to be using 4 PSI 15s on a temporary Sundown 2000 until I upgrade to a Bigger one. But this is what I have going so far..
The specs for the box are: 40x48x20. HeightxWidthxDepth. The total Volume without displacement comes up to 19 ft^3. And the tuning to 35hz.
I just wanted to see if you guys think this would work. And also for the bracing I am not fully decided that I am going to be using what is in this design. I need some feedback to see if this would work or if I need to change it up..
Old 04-05-2013, 07:01 PM
Infinitelybaffled's Avatar
0/11 ssssss816
Port looks kinda small. Whats port area like?
Inappropriate sig image.
Old 04-05-2013, 07:06 PM
0/11 sssssss21
Torres box says 120 in^2. I dont really know how that translates, and for the ratio: 1:3.33. idk if that is needed
I should add the dimension of the port are 20 in. tall, 10 in. wide, and 5 in. deep.
Old 04-05-2013, 07:37 PM
0/11 ssssss816
Yup. Raise port area for sure. Tune to whatever you like but I would use about 3 more cubes worth of airspace for the port. 16 cubes net is still pretty big for 4 15's
Old 04-05-2013, 07:46 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
120 sq in is very low for 4 15s. Probably would want around 200 sq in for the 4 I would think.
edit: Now Im a little confused you said 120 sq in port but if these dimensions are correct.
Then 20 tall x 10 wide is 200sq in and the port is 5" deep?
Old 04-05-2013, 09:08 PM
0/11 sssssss21
Yes you are correct those are the dimensions of the port. So yeah that is what im wondering now..
The 5 I was talking about start from the from the inside of the box.(Im not including the double front baffle)
Old 04-05-2013, 10:02 PM
0/11 sssssss21
Well here is another design I just did. I made the port taller and it goes in alot more deep inside.
Old 04-05-2013, 10:18 PM
Team Ampere Audio
0/11 ssssss779
I like it. Im designing a wall for 3-zv3 15s rite now as we speaK!!!
Old 04-05-2013, 10:43 PM
0/11 sssssss21
Post some pics I would love to see it!
Tags
psi wall build box
4 Obsidian 15s wall on DD m3 kr-15 Car Audio Videos 5 03-31-2013 03:36 PM
4 15s flat wall or 2 15s large ratio 4th? mads10bass General Car Audio Discussion & Questions 7 02-04-2013 01:13 AM
Level 5 15s in my wall!!!! codyj18 (DC) 20 12-15-2012 10:24 PM
Bumpin Dodge's 2003 Ram Build Log 4 lvl4 15s crescendo 3k wall Bumpin Dodge Build Logs 178 06-16-2012 10:39 PM
plumbcrazy 2 15s xfl's wall build Plumbcrazy Build Logs 27 04-14-2011 08:50 PM
