Cancelation issues?!? - Car Audio Classifieds!
Old 04-05-2013, 09:50 PM
Twitney181's Avatar
0/11 ssssss591
Default Cancelation issues?!?
Is this design going to cause cancelation issues with the inner two subs? They will be 11 inches apart from each other on the inside
In the pic the box is upside down, so that 11" x 5" part is the port which will be on top. Ad in the bigger one there will be two subs mounted on each side firing towards eachother and then 2 on the front 2 flat parts firing forwards, will I have any issues with this?
Old 04-05-2013, 10:18 PM
Twitney181's Avatar
0/11 ssssss591
Anybody?
Old 04-06-2013, 12:10 PM
Twitney181's Avatar
0/11 ssssss591
Well damn
Old 04-06-2013, 12:17 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Yea, normally doesn't take this long for a helpful response...
Sent from my SPH-D700 using Tapatalk 2
Old 04-06-2013, 12:20 PM
That's because there is only a handful of people that could answer this question. You will be fine, it's not really optimal but it won't cancel out. The biggest difference you will see is loading. The 2 inside subs are going to move much less then the outside ones.
Old 04-06-2013, 12:22 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
did you come up with this design?
Old 04-06-2013, 12:25 PM
Twitney181's Avatar
0/11 ssssss591
Yeah I did it was originally supposed to be this but the subs would hit surround on eachother when playing ha
Old 04-06-2013, 12:26 PM
Twitney181's Avatar
0/11 ssssss591
Ok thank you. Will them bring mounted like that cause a big loss in output?
Old 04-06-2013, 01:02 PM
i ♥ Sundown Audio
0/11 sssss1946
just do two on top and two on the front
Old 04-06-2013, 01:03 PM
0/11 sssss2096
If the subs are female and touch each other, small problem. If the subs are male, well.........
The Following User Says Thank You to jackson81 For This Useful Post:
Twitney181 (04-06-2013)
2.0K issues edouble101 (DC) 14 02-05-2012 10:25 PM
Cancelation issues in 02 Sonoma detroitdiesel Enclosure Discussion & Design Construction Help 5 11-14-2011 04:01 PM
anyone else having issues? pitbull1078 (DC) 23 03-22-2011 04:17 PM
Altima Noise Cancelation old_greg13 General Car Audio Discussion & Questions 4 01-11-2011 10:40 AM
TL issues Highs On Bass General Car Audio Discussion & Questions 3 11-06-2010 02:00 PM
