4 sa8s port question - Car Audio Classifieds!
Old 04-08-2013, 12:53 AM
0/11 sssssss20
Default 4 sa8s port question
Im doing a build soon for someone and its going under the seat of a 02 chevy silverado extended cab.Now my major question for the box is port area,iv been reading on the forum and found someone saying to use a 4" aeroport tuned to 32-36hz. So i did the math on torres and I can get 2.25 cubes with the subs and a single 4" aeroport tuned to 32.08hz with it being 11 3/4" long. Would i need to worry about port noise? Thanks for any reply on this.
Old 04-08-2013, 01:00 AM
0/11 ssssss108
I'd do a single 4" aero per pair of subs, one port on each side facing the rear doors, adjust length accordingly to get the tuning desired.
The Following User Says Thank You to TRTC360 For This Useful Post:
garren (04-08-2013)
Old 04-08-2013, 01:31 AM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Def do 1 4" aero per pair, I'm running 2 sa8v2 in 1.4ish and I have a full 4" aero which is about 17" and its only 8"per cube.
The Following User Says Thank You to its_ray_ray For This Useful Post:
garren (04-08-2013)
Old 04-08-2013, 02:16 AM
0/11 sssssss20
Deciding on doing 3 3" aeros to get a rough total of .51-.52 per 8 at 35hz and 21sq in of port area,should be fairly loud lol,thanks for the help
Old 04-08-2013, 03:16 AM
OCD Member
0/11 sssss5696
How much power you running?
Old 04-08-2013, 09:20 AM
0/11 sssssss20
Well from what info he gave me around 3k give or take
Old 04-08-2013, 09:30 AM
0/11 sssssss20
So 750 each
Old 05-20-2013, 10:53 AM
0/11 sssssss20
Box turned out awesome. Went with the 4" aero and tuned it to 35hz, and i also resined the entire box. Slammed harder than 2 10s he had before.
question about L port and center firing port fyerbyrd22 Enclosure Discussion & Design Construction Help 10 10-10-2012 04:51 PM
Question about port up vs port back 916slapin Enclosure Discussion & Design Construction Help 8 03-14-2012 08:14 AM
port question kush killer Enclosure Discussion & Design Construction Help 13 09-28-2011 12:56 PM
Aero port size for 4 sundown sa8s BassHead143 (Sundown Audio) 26 06-28-2011 10:27 PM
Port question Wisneaky General Car Audio Discussion & Questions 2 08-30-2010 04:17 PM
