Port Area NOOB! - Car Audio Classifieds!
Old 04-13-2013, 02:14 AM
Spl-zx2's Avatar
Bass Brotha
0/11 sssssss81
Default Port Area NOOB!
So im building a lower tuned box for my two skar vvx 12s and I have no idea what im doing when it comes to port area.I think I have the right sized box and right tuning frequency,I just want to know if the port area is right.My goal is to be loud from 26-33 hz.Not going to be metering alot so yeah.Will be running em on about 1500-1700 rms.Thanks.
Uploaded with ImageShack.us
Old 04-13-2013, 02:24 AM
fivedollapizza's Avatar
0/11 ssssss314
Fellow noob here but I can tell you with 28 sq/in of port for just my sa8s on 1100 I have port noise. Probably should go closer to 30-32 or more.
Have never ran those subs so I don't know exactly what they like.
sent from my gs3
Old 04-13-2013, 02:27 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
3.5 cubes you want at least 45" of port with a slot port
OR
Get a 6" aero. Make it 17-18" long. screw it in. be done.lol
-Youtube Channel
Old 04-13-2013, 02:30 AM
0/11 ssssss314
OR
Didn't even look at the box size. Assumed everyone has a 1 cu/ft box lol
sent from my gs3
Old 04-13-2013, 02:35 AM
Spl-zx2's Avatar
Bass Brotha
0/11 sssssss81
lol.So how the hell do i get more port area but keep lower tuning?
Old 04-13-2013, 03:02 AM
Spl-zx2's Avatar
Bass Brotha
0/11 sssssss81
Okay so Ive done a little more research and I got it at 36sq port area at 29hz
Old 04-13-2013, 04:24 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
People usually shoot for ~ 12-15 square inches of port per cubic foot of box when using a slot. You can sometimes get away with less port area when tuning lower like you're trying to do, but at 8 sq in per cube like you have, you're flirting with having serious port noise.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Spl-zx2 (04-13-2013)
Old 04-13-2013, 09:05 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
still too little. need at LEAST 42". Id want ~50. As to your previous question on how you get enough port and still get low tuning, well, welcome to the challenges of box design lol. Slot ports are a pain in the ass, especially in smaller sized boxes, to get enough port, the correct net displacement, and still obtain the desired tuning. That's why I STRONGLY suggest using a 6" aero port.
Also, another bit of food for thought, even though you want to play strong in the mid-upper 20's, that doesnt mean you necessarily need to tune that low. I'd say, if you were to tune at 30-31 with a 6" aero port in the same airspace you're looking at, it would do awesome. It'd be easy to build, easy to tune, and aero's are just more awesomer.lol
EDIT: This is exactly what I'd do. ~3.5 cubes net, single 6" aero kit from parts express and full length, and slop the bitch in the box. thing would sound awesome. Also, if you're still open for thoughts, if you are going to use an aero, you may to consider side firing it towards the drivers wheel well at the back most part of the box. The "Anton Miller" style box if you will
-Youtube Channel
The Following User Says Thank You to taylorpro For This Useful Post:
Spl-zx2 (04-14-2013)
Old 04-13-2013, 09:43 AM
0/11 sssssss38
Noob question but your port area isn't calculated into your box volume correct? It'll be box volume plus port area?
Old 04-13-2013, 09:44 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
The volume the port "takes up" inside the box is subtracted from the GROSS volume. Alot of times, like in torres, after you subtract these different things, you get the NET volume. (Reference the right rows of info from the pic i posted to see what i mean)
-Youtube Channel
Port area witherman Enclosure Discussion & Design Construction Help 2 10-02-2012 11:58 AM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
OA 15 Port Area Kidthump General Car Audio Discussion & Questions 5 09-08-2011 12:04 AM
