SA8 Box for a friend - Car Audio Classifieds!
Old 04-15-2013, 07:12 PM
PapaGeno21's Avatar
0/11 ssssss448
Default SA8 Box for a friend
Ok so I am building a box for my buddy. We are going to be using two SA8 V1.5's ported.
All he listens to is rock and classic rock etc.
Looking to see what I should tune this thing too and how much port area I should use for this thing to crank for him.
We are going to use one of the PPI 1000 watt amps for it.
Suggestions? Need to know port area, port area per foot, and tuning.
Do you think these subs will work well for that? He is currently using two old ass rockford 10's cheap line version in a prefab ported box on a 250 watt sony amp most likely clipped to hell.
Thanks!
03 Suburban
| Pioneer | FU Audio |
Rockville Audio | Crescendo | XS Power | SHCA & Knu | CDT | DC Power | Sundown | AudioTechnix |
Old 04-17-2013, 01:01 PM
0/11 sssssss70
Thanks!
Well I guess I better get my post count going. I will try and help. If you have any questions/comments, let me know.
I went through a wide range of enclosure sizes and tuning frequencies and I think an enclosure with a net volume of 1.0ft^3 tuned at 35hz would be ideal for this setup. You would get a +/-3db range from 32hz to 200hz. I had it setup as a slot port 1.75" wide x 9.25" tall and it needs to be 32" long. Here is a quick draw up I did (just as a suggestion) build it however you want. I am not an expert by any means so if anyone see's some flaws please learn me some more knowledge.
Old 04-17-2013, 01:05 PM
0/11 sssssss70
I made a small error. The port should be 2" x 8.5" (that is internal dimensions). I calculated all this using 3/4" mdf. So the external port dimension is 2.75" x 10".
Old 04-18-2013, 01:23 PM
PapaGeno21's Avatar
0/11 ssssss448
Thanks a lot man! Will take those specs into account. You think the box being that small is ok?
Sent from my EVO 4G of justice
03 Suburban
Old 04-18-2013, 03:45 PM
0/11 sssssss70
The Sundown 8' subwoofers "were made" for small enclosure's. They can be larger, but perform very well in small enclosure's.
Old 04-19-2013, 09:49 AM
PapaGeno21's Avatar
0/11 ssssss448
That's good to know. The smaller the better for what he is looking for.
03 Suburban
Help with box for my friend 2 12 polk db drsnazzy Enclosure Discussion & Design Construction Help 13 03-14-2012 04:20 PM
single sa 10 box for a friend 2000LaDe (Sundown Audio) 7 06-16-2011 11:47 AM
box i built for a friend 3rdshiftdiscretion General Car Audio Discussion & Questions 4 10-21-2010 11:32 AM
WTB sub box for friend Audio_Prodigy Wanting to Buy (WTB) 12 09-26-2010 01:46 PM
Box for Skip01's friend dcarcstms Build Logs 12 06-06-2010 06:00 PM
