Plexi window on box - Car Audio Classifieds!
Old 04-18-2013, 10:01 AM
0/11 sssss3842
Default Plexi window on box
Planning to do a plexi glass window on my next box. Box will be fore 4 SA12s on around 3k.
My question is what thickness of plexiglass wouldbe safe? 1/2" sufficient? Would it depend on the size of the plexi? the box will be built from 3/4 MDF and the rear wall will be where the window is. Will be flush mount window.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 04-18-2013, 10:05 AM
Micksh's Avatar
0/11 sssss2596
Unless the window is tiny, you should use 3/4"...
My Youtube page
Astro build log link
The Following User Says Thank You to Micksh For This Useful Post:
audioarsonal (04-18-2013)
Old 04-18-2013, 10:06 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Yeah unless the window is only 8x8 or less you want to go with 3/4 to avoid any flex.
Old 04-18-2013, 10:26 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
^^^This. And leakage is the biggest drawback on windows too. The smaller the window, the better off you are.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 04-18-2013, 10:50 AM
0/11 sssss3842
Planning on using Aeros so window will be across the back and probably only 8" tall by 2-3 foot wide.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 04-18-2013, 10:54 AM
mega fatty
0/11 sssss6008
I would double baffle the back wall and samich it between the baffles
07 mazdaspeed3
rd d9 @ .5ohm
Old 04-18-2013, 11:16 AM
0/11 sssss2011
Feedback Score: 61 reviews
on the baffle/wall that the plexi is going on, make the plexi as an insert piece that'll sit flush with the original baffle. if you're using 3/4" mdf use 3/4" plexi. here's how i did my last plexi window. made baffle out of 3/4" mdf and cut out the positive shape of the window than made the negative shape out of plexi so it would fit right in. than made a 1/2" baffle to match the positive with a 2" lip for the plexi to mount to. the plexi actually pressure fit into the piece pretty tight once the box was wrapped. I used t nuts with hex head bolts to mount it, i recessed them 1/8" into the plex. I can't wait to do my next one.
Old 04-18-2013, 11:24 AM
Twitney181's Avatar
0/11 ssssss591
I just built a box for 4 sa 10's with 2 9" x 9" plexi windows, I did 3/4 thick, and had them so they lay flat on the rear, and then I cut out another piece that sits around the plexi so that it's all flush, and then i took the plexi off and glued the 2nd piece to it so the back is doubled up.
I used 2" bolts, washers on both sides and a pressure washer inside, all 4" apart with 1/2" wide and 1/2" thick weather stripping to bolt it down and seal it off. (Didn't wanna just screw it down, so now if my tuning is off or I wanna go lower I can take out the window and easily add to the port without worrying about it stripping out the wood
Old 04-18-2013, 02:03 PM
0/11 sssss3842
Yalls ideas sound great but having a hard time visualizing it. anyone with pics?
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 04-18-2013, 02:20 PM
0/11 sssss2011
just so you can visualize it here is a pic of a template. we'll call the larger template, A, and the smaller one, B.
take A, trace it on to your 3/4" baffle. cut out on line (way more detailed way to do this with precision). place A onto piece of plexi, router out shape. place your 3/4" and 1/2" baffle on one another, place insert into 3/4" baffle and router out inside of A. now assemble 3/4" and 1/2" baffles, finish as desired. place plexi into opening and attach with bolts. obviously this is overly simplified. maybe I should make a video or something. B should be the rough size of your window.
Interesting old IASCA plexi box RE_XXX General Car Audio Discussion & Questions 26 04-05-2012 05:14 PM
Crossfire 18" & AB amp, box, plexi.. Norf, VA chrishova Craigslist Deals 0 03-09-2012 10:21 AM
3/4 Plexi 22.5 x 34.5 Cojones24 Wiring, Electrical & Other Installation Equipment 3 10-06-2010 03:30 AM
info on plexi box build??? bobbygilly Off Topic Chat 40 09-17-2010 09:04 PM
