Aeroport without the flare? - Car Audio Classifieds!
Old 04-18-2013, 01:38 PM
Beatdown337's Avatar
0/11 sssss1535
Default Aeroport without the flare?
I know that everyone gets the precision kits from parts express and madisound, (as do I) but im doing an install for a guy locally and we're cutting it really close on the budget. He's going to need 2 6 inch aeros for the tuning to be right and i saw that Lowe's has the green pvc pipe that everyone uses but of course that would leave us without flares. How detrimental would it be to not have flares with aeros this size? Any input is appreciated
Old 04-18-2013, 01:42 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
The flares increase the efficiency a lot on real aeros or flared pvc ports.
How many cubes is the box and what subs and power will you be using?
Old 04-18-2013, 01:43 PM
0/11 ssssss484
You can boil some oil .put the pipe in it and push it over a bowl
Old 04-18-2013, 01:48 PM
0/11 sssss1513
Feedback Score: 17 reviews
heat gun and a bowl will work also
Old 04-18-2013, 02:04 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
I used one of those 100,000 BTU propane torpedo looking space heaters to heat the pipe and used a bowl. Much, much faster.
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 04-18-2013, 02:07 PM
0/11 sssss2011
Feedback Score: 61 reviews
an "Aeroport" is a model of a brand that makes ports it's not just a port tube. you have just a round port unless you buy or make a round port with flared ends.
Old 04-18-2013, 02:38 PM
0/11 sssssss52
Do this
Old 04-18-2013, 02:54 PM
0/11 sssss1535
the box is a bit small (9 cu ft)for the 6 l7 12's it will be housing. And it will be powered by approx 6k
Old 04-18-2013, 02:55 PM
0/11 sssss8594
Feedback Score: 55 reviews
it really is install dependent...but yes, in alot of cases, the flare does help...even a small flare is better than no flare usually...i forget the formula but there is a formula for the correct way to make the flare...like, the total radius and the flange and shit
Enclosures
Old 04-18-2013, 04:15 PM
0/11 sssss1535
i guess my question is even though im losing some of the positives by now having the flare, since a round port is generally thought to be more efficient than a slot it could possibly work ok? And by the way i saw something that somewhat looked like a flare but it was in the section with the toilet flanges
homeade 8" aeroport flare build btsteinb Build Logs 12 02-24-2013 10:23 PM
WTB 6" PSP flare Munkee Wanting to Buy (WTB) 0 01-08-2013 04:36 PM
Port flare from backside? 3rdshiftdiscretion Enclosure Discussion & Design Construction Help 3 05-28-2011 02:39 PM
WANT: Single 4" port flare Novicaine Wanting to Buy (WTB) 4 12-31-2010 02:23 PM
WTB 12" port flare Eddie Havok Wanting to Buy (WTB) 1 10-02-2010 10:27 PM
