box help 1 15'' Massive Audio DMX stg2 - Car Audio Classifieds!
Old 04-19-2013, 06:00 AM
0/11 sssssss14
Question box help 1 15'' Massive Audio DMX stg2
looking for some help building a ported box for a DMX stg2 15'' its going in a 2000 toyota camry. trunk measures 40W X 20H X 30 inches deep. i was recommended 3 cubic feet at 33hz im only wanting to run 1000 watts rms from a sundown audio SAZ1000D amp on this at first and if i get bored i will bump it up to 1500 watts rms. also if i can run this sub in a enclosure it would be fine too. ive been trying to mess with a box builder but im thinking they are all not as accurate as they could be. I also tried to email massive audio last week with no luck. i will be calling them whenever they open for business. any help would be great.
Old 04-19-2013, 02:18 PM
0/11 sssssss14
Looking to have the box 3 cubic feet at 42 hz port should be 12x3.5x10 inches. Xmax is 27mm if this info helps.
Old 04-19-2013, 02:25 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
what orientation? sub up/port side,sub up/port up,sub forward/port forward?
My game is legit,
Old 04-19-2013, 03:30 PM
0/11 sssssss14
Sub forward/port forward if possible my seats fold down so it would be nice to look at the sub/ port. if not sub up/ port forward. Thankyou for your time
Old 04-21-2013, 03:32 PM
0/11 sssssss14
anyone one at all. forget the box specs. because obviously its not gonna work. ive tried using RE calculator with No luck at all. im really confused on what to do here. i should just pay someone already. i dont even get the calcuations for it. math owns me
Old 04-21-2013, 04:10 PM
qopiyu's Avatar
0/11 ssssss531
Torres calc says:
16.5 h x 30 w x 18 d
port: 15 h x 4 w x 22 l
result: 3.03 net volume, 60 in2 of port, 41.89 Hz tunning
Box would look kinda like my avatar, except use 1 sub of course.
Old 04-21-2013, 04:27 PM
0/11 sssssss14
Heres specs. Im confused if i got the frequency right. 42 sounds high
box volume : 3 cubic feet
fill :none
Fb: 42hz
port size 12''x3.5'')x10
Fp:37.46hz
watts @ music:1500 watts
Xmax @ music: 27MM
SPL @ Music: 131.5 DB
Old 04-21-2013, 05:54 PM
qopiyu's Avatar
0/11 ssssss531
Your port size is for a box that is 13.5" tall. (13.5" - 1.5" (that 2 3/4" boards for top and bottom)) you get 12" tall for the port. This spec is for a box for 12" subs.....
Old 04-21-2013, 06:03 PM
0/11 sssssss14
The heck? Im looking at the dmx 15" specs and it says 12x3.5x10 they must have mixed it up? No wonder I'm screwed up
Old 04-22-2013, 11:04 AM
0/11 sssssss14
Changed my mind any help with this? im now wanting a box that is 3 cubic feet at 33-35 hz. What about this box? I used RE box calculator
30w x 17h x 16 d
Port is 2.5 w x 12.75 l x 15.5 H
Says the box is 3.1 cubic feet at 33.11 hz
I could probably make the box wider and slightly bigger on the depth
2 Massive audio DMX 15 STG2 flboy4x4 15" Subwoofers 12 11-14-2011 11:35 AM
15'' massive audio bmx stg2 1outof7 15" Subwoofers 7 09-11-2010 10:32 AM
F/S: Massive Dmx Stg2 15" Motor/Basket-$50+shipping smalltown Speaker Accessories & Parts 11 06-25-2010 04:58 PM
Blown 15" Massive Audio DMX Stg2(Motor/Basket good condition) smalltown Broken & Non-working equipment 10 11-22-2009 11:34 PM
