Routing the back of speaker holes gain?? - Car Audio Classifieds!
Old 04-19-2013, 01:17 PM
vince79vette's Avatar
0/11 sssss2011
Default Routing the back of speaker holes gain??
I was reading some ones post on another build and saw they routed the back of the speaker holes and u will gain on spl. What do u all think
Old 04-19-2013, 01:19 PM
tommytee's Avatar
0/11 ssssss515
if your face plate is thick,like 5 or 6 layers yes it will help.other than that no.
2010 gmc sierra. Walled 4 18's 2 taramps 12k.
Team taramps, team ds18, team digital design, team Xstreamaudio.
Old 04-19-2013, 01:20 PM
badmofo529's Avatar
0/11 sssss3329
rounded over the rear of baffle you mean? it will gain a little if you have a deep baffle. gives the rear waves a smoother transition
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 04-19-2013, 01:25 PM
0/11 ssssss761
I only have 3 baffles and flared the back as much as possible and gain more then a db
J.D. Merkle
TEAM SOUTH
4 DD 9512H
2 DD M4a
The Following 2 Users Say Thank You to Beatnoutdaframe For This Useful Post:
djscrubb (04-19-2013), n8skow (04-19-2013)
Old 04-19-2013, 01:28 PM
tacomaguy1's Avatar
0/11 sssss4401
kind of hard to believe...but if it did that's a really nice gain
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 04-19-2013, 04:59 PM
n8skow's Avatar
0/11 sssss1519
Sharp edges = turbulence... Anywhere you can eliminate it will help with SPL...
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
Old 04-19-2013, 05:08 PM
SoCaLBaMF's Avatar
0/11 ssssss469
Mine does... my baffle is super thick though
Trailblazer
(4)18" Sundown Nightshade V3s
(2)DC power SP 270s, (14)D3100s, (1)D6500
(12) Lanzar Opti6pm and (4) FT1 supertweet
(4)Lanzar Opti 6ks, Lanzar Opti 1600x2, Opti 250.2, and Opti 100.4
Old 04-19-2013, 05:29 PM
0/11 sssss2095
Indeed, hard to believe, but if it dose work, wouldn't the sub manufacturer already have done it? dam posted in the wrong place
Anybody ever try the Eminence ALPHA-8MRA - CLOSED BACK MIDRANGE speaker Mnorwood01 General Car Audio Discussion & Questions 18 01-02-2013 10:39 AM
Gain vs Speaker impedance and current draw Dammed General Car Audio Discussion & Questions 6 06-17-2011 08:47 AM
Cutting speaker holes into kick panels Ccab81 General Car Audio Discussion & Questions 41 04-13-2010 01:35 PM
Second Skin Speaker Tweaker Pads Back In Stock old CACO Admin (Second Skin) 10 03-06-2010 11:43 PM
Machining/Routing Aluminum wasted ink Tutorials & Quick References 2 12-07-2008 08:09 PM
