Easy to build 6th. Problems? - Car Audio Classifieds!
Old 04-20-2013, 09:22 AM
0/11 ssssss463
Default Easy to build 6th. Problems?
My main concern is the interior ports firing at each other. There is 13" between them. Do you think that is enough to avoid interference. I can move one to the other side if need be.
Old 05-22-2013, 11:52 PM
0/11 sssssss20
That looks pretty good, doing my first 6th right now, suprisingly easier to design than a 4th
Old 05-26-2013, 01:03 PM
rc610's Avatar
0/11 ssssss285
Hate to bump an old thread but just how do I go about figuring out what to tune the 2 halves too when designing a 6th?
Bought from: bear gri11z, nutxo, 12voltz+-, newarkbeast973, 98Expo, joe*89, Nate Futuristic,
Old 05-26-2013, 03:56 PM
0/11 sssssss20
genearally its by getting your first tuning say in the rear chamber, i did mine at 32hz, one octave above that is 64, but i was worried about a peaky responce and tuned that to 55hz. Also i used a 3" aero for my rear which was like 14 long and shared between chambers. And i used about 3/4 of the cone area of the subwoofer i used as my front chambers port volume. Im still learning but i did that and got a super flat responce with a awesome frew range from high 20s to around 55-60 area.
Old 05-26-2013, 03:57 PM
0/11 sssssss20
If youd like message me and il design you something
Old 05-29-2013, 11:50 AM
rc610's Avatar
0/11 ssssss285
Cool thanks. I may just do that on down the line. I don't want to try it before scraping the coast because with my work schedule I, not sure ill be able to finish it in time
My first sa8v.2 6th order build Jeffhulbert50 (Sundown Audio) 4 11-21-2012 03:13 PM
4 18's Series Tuned 6th build Infinitelybaffled Build Logs 73 10-13-2012 11:48 PM
Easy box build iamthewalrus Box Requests 6 09-18-2012 02:08 PM
How to build a 6th order box??? Shutdownaudio General Car Audio Discussion & Questions 9 02-14-2011 10:57 PM
who wants easy money, 2 tiny brackets PICS of MAYHEM build kryptonitewhite Wanting to Buy (WTB) 2 10-14-2010 03:19 PM
