aeroport help(DD 9515) - Car Audio Classifieds!
Old 04-21-2013, 08:10 PM
0/11 sssssss45
Default aeroport help(DD 9515)
Im designing a box for my sub and i cant figure out how many aeros of what size to use. My box will 3.62 cubes and I will be tuning to 38hz. Any advice is greatly appreciated thanks.
Old 04-21-2013, 08:14 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
Google "Chris Torres Box Calc" and download it
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 04-25-2013, 09:51 AM
0/11 sssssss45
Well i have a general idea i either one 1-2 6 inch(if 2 fit) or 2-4 4 inch im looking to move the most air possible obviously 2 6 inch aeros will flow better but is it an over kill? will i be sacrificing pressure if i use 2 6 inchers?
Old 04-25-2013, 10:39 AM
0/11 ssssss816
Feedback Score: 22 reviews
with a box that small for a single 15, not including the displacement the ports will take up, 2 6" ports will need to be roughly 25" long to get the tuning you are after. That is def. not too much port for a 9515, dd's work great with above avg. port area, but you are a bit small on the box volume IMO. How much power do you have?
0/11 ssssss568
you want at least 2 6 inch aero ports. possibly 3 for that sub
Old 04-25-2013, 10:40 AM
0/11 ssssss568
i wouldnt advise that small of a box for a DD 15. i would down grade to a 12 and be louder. unless you are giving it a lot of power. you are just going to be suffocating it
Old 04-25-2013, 10:42 AM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
For that size, you will want to use a single 8" Aero. Don't expect it to be real musical though.
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
The Following User Says Thank You to bigdhenderson For This Useful Post:
bump4life (04-25-2013)
Old 04-25-2013, 10:43 AM
0/11 sssss4981
I use to run my 9515 in 3.25 with 70" of port. Wasn't great on music, but it was louder on the meter than other boxes I tried
SENSE RESISTANCE
Old 04-25-2013, 07:35 PM
0/11 sssssss45
its work in progress but for now ill be running a lanzar opti2001D([email protected]) and in a few months save up for another one and strap them and eventually end up at an M3a/b
The 3.62 is after displacement and everything if that makes it better. What would be the optimal cubes to get both musical and mid spl(its alright to sacrifice spl since itll be in my dd
so single 8 will be better than 2 6s?
Old 04-25-2013, 07:40 PM
0/11 sssss4981
What kind of music do you listen to?
What kind of car do you have?
What kind of power do you have on tap?
SENSE RESISTANCE
aeroport help hdman87 Enclosure Discussion & Design Construction Help 3 01-12-2013 09:13 PM
Fs: Dd 9515 josh berglund 15" Subwoofers 57 02-28-2012 02:00 AM
Dd 9515 d2 or D0.5 gln305 Wanting to Buy (WTB) 9 02-03-2011 07:00 PM
Dd 9515 f gary2k7 15" Subwoofers 9 10-02-2010 07:18 PM
Aeroport Help Please?!? Pieper Enclosure Discussion & Design Construction Help 6 04-18-2010 06:04 PM
