JL W3 18's 4th order - Car Audio Classifieds!
Old 04-22-2013, 09:15 PM
0/11 sssssss60
Default JL W3 18's 4th order
One of my buddies made me a really good offer on some JL W3 18s and I wanna put them in a 4th order. not really sure on the specs of this woofer because it was discontinued.
basically i just need to know what the optimal sealed/ported ratio would be.. im assuming 3:1.
basically im afraid of making the sealed too big. what would be good for the sealed part? on winisd it says 6 cubic feet sealed and 18 cubic feet ported will do decently well. any ideas guys? i just dont wanna give too much space and overcome the ability of these woofers.
Old 04-22-2013, 09:20 PM
0/11 ssss31258
if you don't know the specs... how can you saw winisd says it will do well?
http://mediacdn.jlaudio.com/media/mf...pdf?1317790193
btw;
6 cu ft rear and 10 cu ft front @ 46hz would make a very nice sounding enclosure.
24" x 6" port 7" long
OR
(6) 4" ports 6.5" long
Goddabri (04-23-2013)
Old 04-22-2013, 09:22 PM
0/11 sssssss60
the woofer is pre programmed into winisd... i just dont know the recommended enclosure sizes and stuff and im not sure if 6 cubes sealed will be pushing the limit
Old 04-22-2013, 09:45 PM
0/11 ssss31258
6 cu ft sealed for two is perfect.
don't forget they are only rated for 500watts each.
also, they deserve something better than an Audiopoop amp.
Old 04-22-2013, 10:07 PM
0/11 sssssss60
right now i got an mbquart 2k and i think they are dual 2 so i will wire them to 2 ohm and give them 650 a piece wich i think they should be fine at because of the quality of them
Old 04-30-2013, 03:55 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Don't think, check, with a dmm. I used to own a pair of 15W3's and they got down and pretty loud. lol...the quality of the subs doesn't mean they will be fine. You could end up wiring them wrong.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 04-30-2013, 04:01 PM
richdog102's Avatar
Handing out Pimp slaps!!!
0/11 ssssss925
they come in d2 and d4 and they do get low...650 will be fine cause you are going sealed..imo i think a 2:1 ratio will work better and they like small sealed enclosures..
People are always tough sitting behind their computer but are bitches in person...
4th order for 2 OA 18's Goddabri Enclosure Discussion & Design Construction Help 5 03-26-2013 05:43 PM
good 18's for a 4th order around $600 Goddabri General Car Audio Discussion & Questions 10 03-25-2013 08:44 AM
FI BL 18's 4th order wall? 98Expo Enclosure Discussion & Design Construction Help 4 01-24-2013 06:14 PM
need a box design. 4th order 2 18's loudcivic Enclosure Discussion & Design Construction Help 0 04-16-2012 07:06 PM
4th order design 2 18's jdmferio13 Enclosure Discussion & Design Construction Help 1 10-21-2010 08:09 PM
