Changing from sealed to ported 2 15's - Car Audio Classifieds!
Old 04-29-2013, 08:32 PM
sgtskip's Avatar
Banannas are bad for you,
0/11 ssssss303
Talking Changing from sealed to ported 2 15's
The Subs are 15" JL W3V2 D4's X 2, Amps for now are MA Audio 589i x 2 so probably around 300w per sub....
The box has an angled front but I did the math and got 6.325 cubes. After taking all of the 3/4 wood its made of away.
External it is
15' tall
34' wide
28' on the bottom
23 1/4 on the top
Internal after I made it square on the front
13.5 tall
31.75 Wide
25.5' Top and Bottom
I would like to find out fhe length and width of two ports, one for each chamber.
I can make a square port if it would be best but I can pop in circle ports easier and faster for now. This enclosure is not a forever enclosure, none of them are!!
PLease Help out
Thanks
Steven "SGTSKiP"
Hate being Bi-Polar...... its Friggen Awesome
Old 05-05-2013, 02:43 PM
sgtskip's Avatar
0/11 ssssss303
Default I found it
I googled and found the owners manuel, it says 2 ports 3" by 11 inches long per chamber. The box is about 1/2 a cube smaller than recomended but I'll add some fiberfill in to fool it.
Im waiting for my Surround repair kit to get here
Skip
Old 10-21-2013, 06:14 AM
sgtskip's Avatar
0/11 ssssss303
Lightbulb UPDATE... A few months late..... ok 6 Months
I FIXED IT, that weekend, but never put the pics up ......
so here they are.... better late than never No beers were harmed in the update of this box...
I glued the ports in and then sealed them on the inside. I also added some fiber fill to it. I went ghetto and sprayed the box black cause it rides in the back of my van, and I wanted to hide the lines I had drawn to do the ports, but my woman covered it with a blanket and you don't see it through the tinted windows....
thanks for looking
Old 10-21-2013, 06:33 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
i see no pics
My game is legit,
Old 10-21-2013, 06:53 AM
sgtskip's Avatar
0/11 ssssss303
Default oooops
more now....I got a slow connection
Hey after 6 months, what's another hour
SKiP
Old 10-21-2013, 07:00 AM
sgtskip's Avatar
0/11 ssssss303
Default more 2
I have to find a few more, or retake some in day light..
more later.... hahaha
Old 10-21-2013, 07:14 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Originally Posted by sgtskip View Post
External it is
15' tall
34' wide
28' on the bottom
23 1/4 on the top
13.5 tall
31.75 Wide
i thought the box was supposed to be big as a house?your pics show a small box.
My game is legit,
Old 10-21-2013, 07:41 AM
sgtskip's Avatar
0/11 ssssss303
Default 2 more.... more l8r
I gotta go to work. more tonight
have a good day guys
Old 10-21-2013, 01:27 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Sooo....you took your old sealed box and put some pvc ports in it is that what I'm seeing??
Not sure that's gonna work...because sealed and ported boxes have diff cubic ft from each other.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-21-2013, 01:37 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
he did mention it is temp and the box will be on the small side but he wanted to port it.
My game is legit,
Tags
jl w3v2 15 d4's
2 12s ported, 2 15s sealed or 1 15 ported? macandcheese General Car Audio Discussion & Questions 25 01-19-2013 09:19 PM
Ported or sealed xbacardi151 General Car Audio Discussion & Questions 6 04-29-2012 08:39 PM
2 12's ported or 2 15's sealed? spencerearl1996 General Car Audio Discussion & Questions 27 01-24-2011 06:12 PM
Sealed or Ported SKDooley General Car Audio Discussion & Questions 3 12-05-2010 08:04 PM
2 15's sealed or 1 15 ported? spencerearl1996 General Car Audio Discussion & Questions 3 09-19-2010 11:36 AM
