6th order are the ports too close? - Car Audio Classifieds!
Old 04-30-2013, 09:38 PM
0/11 ssssss463
Default 6th order are the ports too close?
Quick design of a 6th for 1-10. My concern is are the ports too close to each other for a parallel 6th.
Old 05-01-2013, 07:37 PM
0/11 ssssss463
no opinions? i dont want to waste wood and time.
Old 05-14-2013, 07:46 PM
0/11 ssssss463
Somebody must know if this has been done. please help!!!
Old 05-14-2013, 07:54 PM
That's fine. The wavelengths at those frequencies are tens of feet long, the overall interaction between ports would be the same no matter where they are on the box.
edit: I'm interested to know how this design turns out. Those chambers are close to the same size and tuning is only .5 octave apart. I have a feeling you are going to unload that sub very easily.
Old 05-14-2013, 08:00 PM
0/11 ssssss463
Idiot noob question: what do mean by unload? Is it good/bad? How would you make it better? I have lots of room to play with
Old 05-14-2013, 08:08 PM
If you don't know what unloading a sub is, I would suggest you try a different design. With the tuning so close and the rear tuned at only 38hz, the sub lacks the proper air "spring" behind it (well, behind or in front, depending on how you look at it) to keep it under control. That's for the most part a pretty educated guess, but you might want to research the design a bit more before building.
Old 05-16-2013, 01:46 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
The port shouldn't just turn and then go out like that with a box that loads. That's a terrible design IMO.
If you want a 6th and you have lots of room, let me design one for you.
4th order or 6th order? why? deanmachine General Car Audio Discussion & Questions 11 01-25-2012 09:32 AM
