2 12" AQ HDC3.0 box help - Car Audio Classifieds!
Old 05-04-2013, 10:41 PM
0/11 sssssss20
Default 2 12" AQ HDC3.0 box help
I will be running 2 HDC3s on a nendo 3500 at .5 ohm and have heard mixed reveiws on box size. how many cubes should i make the box. I was also wondering about port size and how people have been tuning these.
Old 05-04-2013, 10:45 PM
0/11 ssssss108
2 cubes net per sub, 16sqin of port per cube tuned to 34hz should get down pretty good
The Following User Says Thank You to TRTC360 For This Useful Post:
obliviant (05-04-2013)
Old 05-04-2013, 11:27 PM
0/11 sssssss20
Another question, i am making the box wedge shaped with port firing up and the port would get wider as it goes down into the box, does the torres calculator account for that or is it more complicated.
Somthing like this.
HDC3 18" box size RidnClean General Car Audio Discussion & Questions 16 06-24-2010 12:55 AM
HDC3 15" Subwoofer Box johnboss General Car Audio Discussion & Questions 5 06-19-2010 01:08 PM
Dual HDC3-A 12" box help csu87 Enclosure Discussion & Design Construction Help 5 04-05-2010 11:50 AM
Box for 2 12" hdc3 1loudmonte General Car Audio Discussion & Questions 11 12-09-2009 12:44 AM
Box build for 12" AQ HDC3 SPY Off Topic Chat 8 10-17-2008 11:03 PM
