4 12's @ 32hz box design Q's - Car Audio Classifieds!
Old 05-07-2013, 05:41 PM
Twitney181's Avatar
0/11 ssssss591
Default 4 12's @ 32hz box design Q's
I designed this box for my buddy and need to know the port length, te port is 8" tall and 13" wide, im wondering do i do 13.5" physical length or do i do 22" long port length? it has 1 common wall. Also it's for 4 pioneer premier champion series pro 12's, he has 2 already on a soundstream rub1.1600, he will be adding 1 more amp and 2 more of the subs.
This is what I came up with, 37" wide x 20.5" tall x 29" deep, plexi window and 6" of space from his rear hatch to the port.
Here's my Torres shit
Old 05-07-2013, 06:17 PM
Mr.G6's Avatar
0/11 sssss4614
your going to need 3/4" thick plexi for it not to flex
2000 Gmc Sonoma ext cab
Old 05-07-2013, 06:22 PM
Twitney181's Avatar
0/11 ssssss591
I know, we already ordered it, 3/4" 9" by 24"
Any input for port length?
Old 05-07-2013, 06:29 PM
Mr.G6's Avatar
0/11 sssss4614
says port needs to be 22" long so it needs to go back 22"
u want shorter port length tune it higher.. but 1.85cubes for a port is decent displacemnt
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
22" long port total depth including the .75" thickness of the wood on the front side where the plexi is. So you would most likely cut your port pieces 21.25" deep and whatever width your port is.
Old 05-07-2013, 06:31 PM
Twitney181's Avatar
0/11 ssssss591
But what about the physical port length on there? I always had read that you go by the physical length
Old 05-12-2013, 06:04 PM
0/11 sssssss20
The physical port length is the length of the actual walls. It is only really different if your port turns.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Ported box for 2 12's tuned to 32hz 3.5 cu.ft. BEEMDUB Wiring, Electrical & Other Installation Equipment 15 08-30-2012 10:08 PM
Compact Box Design for SA-12's? 18inchbangin (Sundown Audio) 4 07-11-2011 08:44 AM
Is this box design good for 2 12's? 18inchbangin General Car Audio Discussion & Questions 0 06-26-2011 11:20 AM
Trying to design a box for 2 obsidian 12's D4 yunghostile Enclosure Discussion & Design Construction Help 10 06-09-2011 02:04 PM
marcothecleptos 2 12's [email protected] 32Hz for local BL marcotheclepto Build Logs 22 12-09-2010 07:38 PM
