2 15" aq hdc3's in a trunk, please help - Car Audio Classifieds!
Old 05-08-2013, 11:26 AM
trunkbomb's Avatar
0/11 ssssss309
Default 2 15" aq hdc3's in a trunk, please help
So I'm going To Be Running 2 15" AQ Hdc3's In The Trunk Of My New Chrysler 200. The Trunk AT The Smallest Points Is 38" Wide And 16" High, And The Box Can Be As Long AS It Had To Be. I Know The Subs Will Fit, I'm Just Having An Issue With The Port Size. I Would Like To Do A Center Slot Port, And With The 3/4" Mdf I'll Be Using, It Can Be 14.5" Tall And Up To About 4" Wide. I Want It TunedAround 38, Is That Possible?
Old 05-08-2013, 11:51 AM
0/11 sssss1943
That would be about enough port for 1 of them.
Old 05-08-2013, 04:04 PM
trunkbomb's Avatar
0/11 ssssss309
So It's Not Going To Be Possible ToRun 2 15s With A Max Width Of 38" And Height Of 16"?
Old 05-08-2013, 04:19 PM
0/11 sssss1480
Feedback Score: 63 reviews
Why does the port only have to be 4" wide. If u plan and measure right. You should be able to make the port 8" wide, possibly. I'm not sure what the cutout diameter is on them
Old 05-08-2013, 04:39 PM
trunkbomb's Avatar
0/11 ssssss309
The Cutout Is 14.1".
So 38" Wide - 1.5" (Outside Wood Panels) = 36.5"
36.5- 31 (Outside Diameter Of 2 Subs Together)=5.5"
So 5.5 " IS All That's Left, And That Doesn't Take Into Account The Wood Thickness To Make The Port....
Old 05-08-2013, 04:40 PM
trunkbomb's Avatar
0/11 ssssss309
I Would love To Be Proved Wrong With My Math, Because Then This Build Might Actually Be Possible
Old 05-08-2013, 05:05 PM
0/11 sssss1480
Cut the sub holes all the way on the edge so that actually the basket will go the outside edge of the box. Same with port. Once again, I don't know the specs of the subs but I bet the mounting flange on them is around .75". So add that back in on both and there is 3" there
Old 05-08-2013, 05:12 PM
0/11 sssss1480
I say go for it. Build the box, cut your sub holes out as far out as possible. Place that baffle on and then make your port accordingly.
My math
36.5-14.1*2=8.3"
Give or take a 1/4 to 1/2" I would think its possible
The Following User Says Thank You to jws84_02 For This Useful Post:
trunkbomb (05-08-2013)
Old 05-08-2013, 08:52 PM
skinnyg's Avatar
0/11 ssssss828
I'm taking it that your rear seats fold down and part of the box will be pretty much sitting on the back seat? How are you getting it into the trunk? Building it in the trunk? I don't think your trunk is going to have enough volume, plus amps, plus batts, etc.
Sent from my Kindle Fire
Old 05-08-2013, 09:19 PM
trunkbomb's Avatar
0/11 ssssss309
The Seats Fold Down, I'll Have 2 Xs 3100 Or 3400 Batts, 140Amp Alt (UpGrade If Needed) But The Box Will Not Be On The Seats, My Trunk Is Roughly 14 Cubic Feet, But Yes I Will Be Building It In The Car. The Trunk Us Absoltuely Enormous.
And IM Either Running 2 Ab Phantom 4000s Or An Aq 3500. Either Way I'll Be Fine With The Power And Electrical, I Wouldn't Ask A Box Question If I Wasnt Confident In What I Was Doing.
2 10" HDC3's soundstream88 Car Audio Trader (WTT) 9 12-16-2011 09:34 AM
2 - 10" AQ HDC3's in Edge brandon_s0854 Enclosure Discussion & Design Construction Help 8 02-24-2011 11:26 AM
WTB: Blown or Possibly Working 2 AQ 12" or 15" HDC3's extreme Wanting to Buy (WTB) 12 01-11-2011 12:47 PM
Electrical for 2 15" HDC3's bass4runner1 General Car Audio Discussion & Questions 12 10-06-2010 11:24 AM
2-10" AQ HDC3's D1 copper resko1 Wanting to Buy (WTB) 3 11-11-2009 09:11 AM
