2 15's @ 30hz box design - Car Audio Classifieds!
Old 05-08-2013, 11:02 AM
Twitney181's Avatar
0/11 ssssss591
Default 2 15's @ 30hz box design
My design that I have come up with gives me 6 cubes and tuned at 30.16hz an I'm wondering if that will be sufficient for 2 15's. (thinking dc or psi on 4-5k)
here are my box specs
20" tall x 35" wide x 25" deep
Port will be above the subs on the face of the box (the 35" by 20" side"
Port Will be 3.5" tall and 22" wide
Tuned at 30.16hz
78" of port area
12.83" per cubic foot
8.43 cubes before displacement
6.0 cubes after port, bracing and sub displacement.
Old 05-08-2013, 11:25 AM
mega fatty
0/11 sssss6008
IMO I would tune to 35
Will help you either get a little more port area or more box volume.
But 6 each with that port area sounds good.
Should be loud
07 mazdaspeed3
rd d9 @ .5ohm
Old 05-08-2013, 11:29 AM
Twitney181's Avatar
0/11 ssssss591
Should be loud
It's 6cubes for both subs, not per sub I really don't listen to anything above 40hz when listening to rap, mostly 25-40hz is about what I listen to, I like the low lows wen not listening to rock. Just worry about it being to small for the 15's
Old 05-08-2013, 11:32 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
i always like to stay closer to 14sqin of port per cube. but depending on the subs you go with, if you are over powering going a little bit tighter on the box will help them handle it.
Old 05-08-2013, 11:34 AM
Twitney181's Avatar
0/11 ssssss591
I was thinking about 2 dc lvl 4's on 2k each
Old 05-08-2013, 11:37 AM
Twitney181's Avatar
0/11 ssssss591
That box would help with the extra power thrown at em
Old 05-08-2013, 11:38 AM
Ryan1126's Avatar
0/11 sssss9178
depending on your electrical you may be over powering a bit so yeah around 3cuft should be fine but if possible bump that port area up a bit.
Old 05-08-2013, 11:40 AM
Mr.G6's Avatar
0/11 sssss4614
isnt this like the 3rd thread youve made about boxes..
kinda seems like to me maybe you like to do local guys boxes..and reallly have no clue on what your doing so you come here for tips and advice right??
2000 Gmc Sonoma ext cab
Old 05-08-2013, 11:41 AM
Twitney181's Avatar
0/11 ssssss591
Bumpin in up to 14.xx puts me at like like 5.8xx cubes. I worry about that being to small. But there will be a 9" x 24" plexi window on the back, and the way I mount it (lay it on the back of te box and bolt it down, the out a piece around that so it sits flush) would take away whatever a piece of 3/4" 8" by 23" wood is.
Old 05-08-2013, 11:42 AM
Ryan1126's Avatar
0/11 sssss9178
well i meant push your variable wall out to allow you to get that extra port area, unless you are at max dimensions?
Box Design for (2)SA-15's 02ls1s10 (Sundown Audio) 11 02-15-2013 10:02 AM
NEED HELP!! Box design for 2 SA-15's sundown banga General Car Audio Discussion & Questions 15 11-21-2012 04:53 PM
Box design for 2 sa 15's rak24540 Enclosure Discussion & Design Construction Help 5 03-14-2012 02:55 PM
my box design for 2 aq sdc2.5 15's badmofo529 Enclosure Discussion & Design Construction Help 3 03-03-2011 10:40 PM
Box design for 2 hdc3 15's, how does it look? Callmety General Car Audio Discussion & Questions 9 05-13-2010 08:21 PM
