Aero port help - Car Audio Classifieds!
Old 05-09-2013, 08:39 AM
Jfool289's Avatar
0/11 ssssss254
Default Aero port help
Does anyone know the minimal sq" of port area per ft3? I know its different then slot ports, like for example, slot ports are usually around 12-16 sq", thanx
2 12" Rival 12.2
4.5ft3 net 10" [email protected]
Crescendo BC5500
3 XS 3100
250 amp Mechman alt
Old 05-09-2013, 08:51 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Id like to stay from 7-10 for a general daily thing. the more excursion capabilities you have, i'd stay on the higher side of that range
-Youtube Channel
Old 05-09-2013, 09:04 AM
Jfool289's Avatar
0/11 ssssss254
Gotcha, thx
2 12" Rival 12.2
Crescendo BC5500
3 XS 3100
250 amp Mechman alt
Old 05-09-2013, 09:57 AM
Mr.G6's Avatar
0/11 sssss4614
^^ what taylor said
i always learned 6 to 10" per
i like to be right in the middle of those.. unless you got a huge xmax sub then go for the larger side
do you know how many sq inchs of port each diff size aero has??
like a 4" is 12.5 sq inchs etc
2000 Gmc Sonoma ext cab
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 02:08 AM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 07:26 PM
aero-port vs. slot port? thumper21 General Car Audio Discussion & Questions 23 03-22-2011 11:12 AM
