4th order or THIS! - Car Audio Classifieds!
Old 05-13-2013, 08:46 PM
0/11 ssssss463
Default 4th order or THIS!
Truck bed cut through. Opening is 19x11.5. Currently with a bandpass 4th 1:2.7 ratio. Sounds OK, but would this be better. Standard vented box mounted in bed.
Old 05-13-2013, 11:50 PM
Depends on the subs and how the 4th order was designed. Try it...it's just wood.
Old 05-13-2013, 11:59 PM
ridintwo6s's Avatar
0/11 sssss1791
do it $60 -$100 in materials, done.
depending on subs could be louder then the 4th.
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 05-14-2013, 06:48 AM
0/11 ssssss463
DC level 4's on a dd M3b 1ohm
Old 05-14-2013, 12:02 PM
0/11 sssssss71
I guess what are you trying to get it to sound like? Does it not play low enough, lack range you like? If you want louder only, the ported may be louder than the 4th. Cant really say becasue it is all in the design.
Old 05-19-2013, 06:51 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
Like what was said before. It's all dependent on what you want to achieve. SPL (Numbers) or LOWS ( GroundPounder).
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 05-19-2013, 07:25 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Why is everyone so obsessed with 4th's? Ya, I'm put my high optimized for ported boxes woofer in a 4th order. Would you put a level 4 in a sealed box? Why not do a 6th order?
The Following User Says Thank You to jt_buck For This Useful Post:
LyferXB9s (05-19-2013)
4th order or 6th order? why? deanmachine General Car Audio Discussion & Questions 11 01-25-2012 09:32 AM
