extended cab center console firing direction - Car Audio Classifieds!
Old 05-19-2013, 08:34 AM
0/11 ssssssss7
Default extended cab center console firing direction
okay going to be 2 skars vvx 10s facing down is the port foward a good idea? i know the port and subs are suppose to load off of a hard surface but if its foward it will only be hitting the dash any downfalls or perks to this? should i have the designer change this to downfire if anyway posssible or are we good to go?
Old 05-19-2013, 09:00 AM
oxsign's Avatar
0/11 sssss1876
I had a crew cab chevy and had buckets in the back. I got the best out of it when the subs were either up or down both ways with the port to the back of the cab.
1971 VW Fastback
Old 05-19-2013, 08:50 PM
0/11 ssssssss7
any other input? anybody ever did this
Old 05-19-2013, 08:52 PM
oxsign's Avatar
0/11 sssss1876
Not many replying cause there's been many threads started about this very thing. Just do some searching and you'll find more info on it.
1971 VW Fastback
Old 05-19-2013, 08:57 PM
skinnyg's Avatar
0/11 ssssss828
Center console, woofers down and port rear. In the ext cab I did better forward firing in my S10, some do better subs up.
I really think a pair of 8s in a 4th would be freekin sweet!
Sent from my Kindle Fire
Old 05-19-2013, 08:59 PM
0/11 ssss31258
I have a crew cab F150 and I replaced my rear console with a center slot ported box using two 10s which also fire downward.
It does well for the low power I run {less than 600 peak to both subs}.
through the winter it's more than enough.
summer comes and I get the itch again.
Old 05-20-2013, 04:10 PM
0/11 ssssssss7
would it be benifical to build a loading wall in front of the port maybe 6 inches? would i gain anything out of it has any body done this before? seems like if it hits a hard surface i will have somthing to gain. inputs
Single cab center console port crackills General Car Audio Discussion & Questions 6 02-07-2013 09:24 PM
Need help on a center console RetroAudioInc General Car Audio Discussion & Questions 15 02-07-2013 06:13 PM
sub firing direction help. smokenyall General Car Audio Discussion & Questions 6 10-20-2011 05:46 PM
Non-Wall Sub / Port Direction In Silverado Crew Cab duramaxxed General Car Audio Discussion & Questions 10 02-25-2010 11:46 AM
Old Celica liftback - sub firing direction? altendky Enclosure Discussion & Design Construction Help 9 08-25-2009 10:03 AM
