Series tuned 6th order for Sony Xplod SVC4 in Saturn trunk - Car Audio Classifieds!
Old 05-20-2013, 10:50 AM
0/11 sssssss20
Default Series tuned 6th order for Sony Xplod SVC4 in Saturn trunk
Iv been working on a design as of now and i would try and post a picture of it but im not home. Rear chamber is tuned to 32hz with a 3" aero shared between each chamber.Also the lower tuned chamber is 1cu3 net after all displacment.Now my front chamber is approx. 1.3 net cu3 and tuned to 57hz with a slot port 12 1/2 x 3x 15 1/2 if i remember correct.I went with a 1:1.3 ratio and also i went with approx 1/4 of the cone area for port on the rear chamber and nearly 3/4 of the cone area for port in the front. Thanks for any help with this box.
Old 05-22-2013, 05:15 PM
0/11 sssssss20
[IMG]file:///C:/Users/Garren/Downloads/attachments%20(36)/20130521_200729.jpg[/IMG], changed it to 32hz rear with 3" aero and can be adjustible to a 2" aero tuned to 26hz up to 35hz using a 3" aero.Also front chamber is now tuned to 64hz
4 18's Series Tuned 6th build Infinitelybaffled Build Logs 73 10-13-2012 10:48 PM
Thinking about a 6th Order in the trunk. Any takers? LEN671 Enclosure Discussion & Design Construction Help 5 07-09-2011 03:58 AM
4th/6th order in a trunk car. Can it be done? k3n12ock Enclosure Discussion & Design Construction Help 8 09-17-2010 08:09 AM
Trunk car 4th/6th order or ?? 98AckCL23 Enclosure Discussion & Design Construction Help 33 07-21-2009 10:24 AM
