slot vs aero in trunk - Car Audio Classifieds!
Old 05-24-2013, 12:01 PM
trunkbomb's Avatar
0/11 ssssss309
Default slot vs aero in trunk
so I'll Be Running 2 12s In 7 Cubes In My Trunk. As I'm Building The Box I'm torn between Using A Slot PortOr 2 6 Inch Aero Ports. The Tuning Is Going To Be 38-40 Hz. Would Anybody Be Able To Enlighten Me As To The sq And Spl DifferencEs Between The 2? I HavE Been Doing A Lot Of Research, But With Everything I Find, Nobody Seems To Have Facts, Just What They Use And Why They Think It Is Better.
Old 05-24-2013, 12:15 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
trunk wall=slot
Subs all the way back to the lid=aero to the cabin
The Following User Says Thank You to tony30cl For This Useful Post:
trunkbomb (05-24-2013)
Old 05-24-2013, 12:17 PM
Timmy13091's Avatar
0/11 ssssss323
I've always done better with slot but blowing in car a single aero should do real well .. What subs you running I'm in Crestwood bro about ten min from ya
The Following User Says Thank You to Timmy13091 For This Useful Post:
Old 05-24-2013, 12:18 PM
AlwaysLearning's Avatar
CACO Late Nite Tip
0/11 ssssss472
What i've seen on the net so far: slot ports are very useful because they are easier to make with big port area than aeros, and they can be bent at the inside end to allow a longer length than aeros.
Slot ports that are very narrow and tall/wide (like very rectangular instead of more square-ish) may produce unexpected results however with output/tuning. More symmetrical shapes like squares and (even better) circles are believed be better, but there isn't really much research on this.
The most important part of the port designs seems to be the correct port area and allowing the port to breathe on both ends. As long as it is, it should sound great
The Following User Says Thank You to AlwaysLearning For This Useful Post:
Old 05-24-2013, 12:28 PM
trunkbomb's Avatar
0/11 ssssss309
the subs Will Be Right Behind The Seats And Sealed Onto The Cabin.
I'm Going To Be Testing Out The New Massive Hippo Line (New For 2013) Some Beefy Little Mofos.
And When You Say Rectangular Ports Can Produce Some "UnExpected Results" Can You Eloborate On That For Me? Do You Mean UNExpected In Tuning, Quality, Ect?
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
you want a slot on the drivers side or in between the two subs
Old 05-24-2013, 12:36 PM
trunkbomb's Avatar
0/11 ssssss309
Why...I Like To Understand Things Before I Do Them
Old 05-24-2013, 12:48 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
Exactly
dont just say you need to do this
Have you tested each orientation in his vehicle with his equipment?
If you want to understand things then do it yourself and test test
not being rude but you cant learn just hitting keys on a keyboard
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 05-24-2013, 12:49 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
port on the drivers side leads to better numbers. in the center will lead to about the same and passenger side port. usually doesnt do nearly as good. you want the port on the opposite side of the meter. (trunk wall) Now on the aeros always in the center long enough to meet your back seats in the cabin with the box all the way to the back of the trunk.
Old 05-24-2013, 01:02 PM
Rocken JBL's Avatar
0/11 ssssss941
Feedback Score: 21 reviews
actually was debating the same thing i run an aero on drivers side but my car meters louder on drivers side.... confusing stuff sometimes and its crazy how things work
Owner-The Dog Pound Car Audio Club, Owensboro
-Team Sundown Audio
-FCBC 200 MOD Champion 2012
-Runner up 200 SD Champion 2011/2010
-MECA AS2 Kentucky state points Champ in 2010
The Following User Says Thank You to Rocken JBL For This Useful Post:
pin2win440 (05-24-2013)
aero or slot gredysra Enclosure Discussion & Design Construction Help 0 05-22-2012 07:21 PM
slot vs aero Russellabt General Car Audio Discussion & Questions 4 11-06-2011 10:04 PM
Aero vs. Slot opinions Xtremelegend General Car Audio Discussion & Questions 29 04-09-2011 05:19 PM
slot vs. aero box and other help needed beatnbronco General Car Audio Discussion & Questions 7 01-10-2011 04:45 PM
aero or slot? Ajax_6154 Enclosure Discussion & Design Construction Help 49 11-06-2010 08:41 PM
