Cant seem to figure out what to do next - Car Audio Classifieds!
Old 05-28-2013, 08:46 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
Default Cant seem to figure out what to do next
now that i know how the car reacts to a wall. Im questioning the final wall build. Either 4 12s(6 12s if they fit) in a 4th (might be on the smaller side not that it matters)
Or 4 15s regular ported in a large enclosure
I dont really have an idea on what i want for a bandwidth if i went for a 4th. maybe 25-40 or something low ish. for the regular ported wall i would tune it around 33 and hope for the best with a ton of port.
explain the reasoning why you would do a 4th/ported. I already know the advantages of each etc but i want to see what you guys would do since im kind of caught between the two. aaaaaaaaaaaand go
Old 05-28-2013, 08:49 PM
HACKMUNCH's Avatar
0/11 sssss3892
Simple,,,,, driver ts parameters should make that decision for u
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 05-28-2013, 09:02 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
well thats another thing. i dont know them yet. not that i dont know the woofer. just not the ts specs. i know a 4th wont be optimal since the q value will be a bit lower than the last. but who knows. Plus its a box thread not woofer and box. im just seeing what you guys would do.
Old 05-29-2013, 12:50 AM
Forty hz is an awfully low upper limit for an intentional* design. You would have too much energy concentrated down in the sub-sonic area...it would be like tuning a vented box to 15hz. Having a big gap in the midbass from say 60-100hz is going to sound horrible.
*It's actually going to be hard to limit it that low without some exotic multi-order design unless your particular transfer function coincides with it. So unless you royally eff it up a 4th should extend out high enough to meet the mid/midbass drivers, although (like I mentioned in the 4th thread), you can expect a pretty sharp roll off on the high end.
I'm very happy with my 4th, and I wouldn't hesitate to build another one. That being said, I will be using a rear-wave alignment in my next build.
Old 05-29-2013, 12:53 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
see thats where the 8'' mid divers come in for 50hz+
i have decided on sticking with the ported wall and tuning in the subsonics actually. have 35 without insert 26 with or something like that.
Help me figure out what sub this is Theundecidedt General Car Audio Discussion & Questions 7 04-22-2013 12:14 PM
Help me figure this out! B MAN General Car Audio Discussion & Questions 65 01-02-2011 02:45 PM
Seeing if anyone can figure this out Boomintahoe General Car Audio Discussion & Questions 10 04-29-2010 08:49 PM
figure this? toad559 Off Topic Chat 5 03-05-2010 08:00 AM
