Tantric HD 10's box? - Car Audio Classifieds!
Old 06-02-2013, 07:57 AM
jheist1991's Avatar
0/11 sssss1070
Default Tantric HD 10's box?
Ok so I'm planning out my next build ahead of time for once, and I got bored so I drew up a box similar to one I had in the past for a pair of 12's.
This time, it will be for a pair of Tantric HD 10 subs. Box is 32 wide, 14 tall, and 15 deep, with the port being 12.5 tall, 2 wide and 24 deep, which supposedly gives me a tuning of right around 31hz.
Can you guys check this design out and see if there's any major flaws with it? The one I had before with great results had the subs up instead of on the front, but that's about the only difference in positioning.
Thanks guys!
which tantric subs would work best in this box? fyerbyrd22 Enclosure Discussion & Design Construction Help 14 05-30-2013 10:09 AM
need box design for 2 12 tantric hd Spena Enclosure Discussion & Design Construction Help 0 01-28-2013 07:28 PM
BoJangles vs. Tantric MD 10's TaylorFade Car Audio Videos 4 11-22-2012 09:27 AM
Tantric Sounds HD 10's TaylorFade 10" Subwoofers 13 09-13-2012 07:14 PM
need help with a box for 4 sa-10's chuck5766 Enclosure Discussion & Design Construction Help 13 10-10-2010 09:23 AM
