CDT SQ-1200 Help - Car Audio Classifieds!
Old 06-13-2013, 10:59 AM
0/11 sssss1056
Default CDT SQ-1200 Help
So I picked up a CDT SQ-1200 for a decent price for my next build. It is a 12 inch cast with an rms of 600, which is right about what I will be putting to it. CDT recommends a very small sealed enclosure, no more than .75. I am no WinISP pro but when I modeled this I could not get a decently flat curve in a sealed enclosure and had almost nothing at the lower end(which I expected sealed)
When I modeled the sub in a ported enclosure, around 1.2 @ 30hz I got a much better looking curve and low end.
Can someone else model this is WinIsp or BB and see what you get? Thanks
Fs = 25 Hz
Qms = 7.2
Vas = 66 liters
Cms = 0.189 mm/N
Mms = 214 g
Rms = 4.678 kg/s
Xmax = 20 mm
Xmech = 30 mm
P-Dia = 251.3 mm
Sd = 495.9 sq.cm
P-Vd = 0.992 liters
Qes = 0.25
Re = 3.8 ohms
Le = 2.3 mH
Z = 4 ohms
BL = 22.6 Tm
Pe = 600 watts
Qts = 0.242
no = 0.398 %
1-W SPL = 88.14 dB
2.83-V SPL = 91.38 dB
JBL Power Series BP-1200.1 old school 1200+rms @ 2 OR 1 ohm!! FullsteeZ Mono Amplifiers 6 03-06-2013 09:19 PM
WTB aq-1200d, skar 1200, rockford t1000-bdcp, sundown 1200 amp FlipperDoodle Wanting to Buy (WTB) 2 02-25-2013 02:18 PM
FS: CDT ES6MO mids, CDT ES 010 tweets, CDT EX530 xovers IAWJ4.7 Component & Coaxial Speakers 8 10-09-2012 09:09 PM
JBL BP-1200.1 Mono Sub Amp - works great- true 1200 watts! ampjunkielikeme Mono Amplifiers 13 06-05-2011 03:29 PM
Want to Buy CDT Audio 4" HD-4's or similar CDT Speakers 2whippets Wanting to Buy (WTB) 1 03-28-2010 02:26 PM
