4th order design 2 xxx 15's - Car Audio Classifieds!
Old 06-16-2013, 05:02 PM
Beatdown337's Avatar
0/11 sssss1535
Default 4th order design 2 xxx 15's
We're working with 2 newer style xxx 15's and it would seem that they would do very well in a 4th. Never done a design like this and to keep from destroying the woofers id like a little help being that I know some of you guys have experience with these. These will run off of a crescendo 5500 at 1 ohm. max dimensions are 49 wide, 31 deep, 26 tall. goals are just to crush the lows daily and move tons of air. (in a normal ported box we would tune to like 30-32 if that helps) Thanks for any input or help
Old 06-16-2013, 05:11 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
tune to 47 with 155sq in of port. aim for a 1:1 ratio with a larger sealed side. 2 ish per.
Old 06-16-2013, 05:19 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
I personally wouldn't do 1:1
Old 06-16-2013, 05:21 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Originally Posted by Jeffhulbert50 View Post
Very much so on the sealed... the xxx 's love a big sealed side
I personally would run with 1.60 sealed per since ur gunna be putting alot of power to them and 7.10 on ported... 16 sq inches of port per cube
If that doesn't fit ur space u listed im sorry, don't have time to calc if it'll fit
but then the sealed res would be high.
4/4 should be good. make sure the subs are inverted. for cooling purposes.
start with 150sq-160
Old 06-16-2013, 05:28 PM
Authorized Vendor
0/11 ssss14115
Thought they were 12s, oops
Old 06-16-2013, 05:31 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Referring to resonant freq? Cus my old truck had the almost exact model subs in a 4th order with 1.45 sealed that beats the shit out of 20 hz all day long with out a fuss
i believe it. I have little experience with these woofers but i know what works. maybe we meet in the middle at 3.6 and 4 ported? deal
Old 06-16-2013, 05:35 PM
Authorized Vendor
0/11 ssss14115
Either way it'll sound good if the port placement orientation is good and not choking
Old 06-16-2013, 05:36 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
this is true. i see alot of failed 4ths that could have been easily avoided lol... dont let this be one!
Old 06-16-2013, 05:37 PM
Authorized Vendor
0/11 ssss14115
Shit lol, I was think 12s this whole time....lul tard... nevermind haha
Old 06-16-2013, 05:38 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
reading helps
07 Impala SS 4th order for 2 15's Whoodwhooker Build Logs 111 01-22-2014 08:51 AM
Need Help with 4th order for 2 SA-15's bigdogjk (Sundown Audio) 3 01-08-2012 05:41 AM
4th order for 2 SA-15's bigdogjk Enclosure Discussion & Design Construction Help 0 01-07-2012 07:52 PM
Box request for xXRaMpOwNaGeXx (4th Order design for 2 SS T4 15's Help) xXRaMpOwNaGeXx Box Requests 1 07-28-2011 12:19 PM
4th order for ss xxx/dc level 6 15 littleharv93 General Car Audio Discussion & Questions 0 07-16-2011 10:49 PM
