first time building a box - Car Audio Classifieds!
Old 06-16-2013, 10:57 PM
0/11 sssssss59
Default first time building a box
hi
im building my first box with an obsidian 15" sub and a vibe blackbox amp([email protected], [email protected], [email protected]), its going in a 2001 dodge stratus. ive got the box built but wondering what to do with the ports and bracing. thinking of an aeroport, either 1 4" or 2 3" ports. not sure if i need any bracing or not. the dimensions are 13.5" high X 25" wide X 23.5" deep. i would like it tuned to around 30htz.. thanks in advance for any help.
[/URL]
[/URL]
Old 06-16-2013, 11:02 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
ull need a 6" or 8" aero
bracing can be 2"x2"s ... or make right triangles and do 2 or so in each corner after ur ports in (to see where not to place them) and then 2x2 cross braces
Old 06-16-2013, 11:28 PM
0/11 ssss31258
I suggest two 4" normal ports 19.5" long. {5ft of 4" PVC will do the job.}
cut the 4.5" holes as perfectly as you can and then use 100% silicone to seal the ports in.
Aero's are NOT needed.
if you built the box well with carpenters glue, bracing is not needed either.
(maybe bracing will be needed someday if you buy a more powerful amp and a larger subwoofer)
Old 06-16-2013, 11:37 PM
0/11 sssssss59
wow, thats big ports. i was figuring about a 4" port. i saw someone use dowels to brace around the sub. also, what is thee best placement of the port, the sub will be facing up, should the port face up or to the front or back or the side?
thanks
Old 06-16-2013, 11:50 PM
Authorized Vendor
0/11 ssss14115
thanks
It can be vehicle dependent... u count fit a port that long facing up..place them where sonic drew them... u can use dowel, just don't get cheap light wood and remember to pre drill...get 1" dowel or ur just wasting time/material... ull want to glue them as well
Old 06-16-2013, 11:52 PM
Authorized Vendor
0/11 ssss14115
Ull want schedule 40 PVC, schedule 80 is ~3.7" inside
If u do 4" ports ^
Old 06-17-2013, 12:18 AM
0/11 ssss31258
there is no reason to use schedule 80. schedule 40 works just fine.
Old 06-17-2013, 12:23 AM
Authorized Vendor
0/11 ssss14115
Right, im mentioning that not all 4" PVC pipes are the same at local lowes/hardware stores...if he buys sched 80 on accident hell have 2 3.786" ports vs 2 4" (3.998")
Quick time lapse of building Skip01 single 8 box dcarcstms Car Audio Videos 21 07-28-2012 10:13 AM
First time building a box, doesnt sound too bad. ImpalaOnDubs Car Audio Videos 13 03-14-2012 12:09 PM
First time building a box ImpalaOnDubs Enclosure Discussion & Design Construction Help 8 03-13-2012 12:37 AM
Building box for two SDC2.5 15"s - First time AQ user. htomeheb General Car Audio Discussion & Questions 10 06-22-2010 11:26 AM
Building first box. KcRidin09 Enclosure Discussion & Design Construction Help 6 03-19-2010 03:00 PM
